Had a search for similar problems, nothing seems to be related to my lazy driverside electric windows.
Very weird problem, on pressing up or down on my driver side window switch nothing happens. However if I then try to do it again about 30-40seconds later it works fine.
If i simply keep trying to push the switch up or down nothing will happen.
Its almost like I need to press a 'get ready to work button' 30 seconds before I intend to wind down my window.
Really anoying at drive throughs. Anyone with a similar problem, or even an explanation?
https://www.sau.com.au/forums/topic/85856-delayed-reaction-electric-window/
exactly the same problem here mate, with a s1 r33.
i pulled out teh switch didnt seem to be anything wrong with it.
sometimes i knock the door with my knee and that gets it going. or i'l pull it up for a second (even when window is up) and then try pressing it down. really annoying.
im thinking of going straight to an auto elec..
Don't know if mine is exactly the same but have R33 Series 1 and the switch seems to stick.
So every time I use the switch for up or down I give it a little wiggle in the "neutral" position to make sure the motor isn't continually trying to go up or down while I am driving along.
Seems to help.
El Bee
