if i get bride/recaro recliners do they also go forward, this is imperitive in a 2 door. Otherwise i will get secopnd hand GTR seats.
do you have alot of cash :P as a racing seat is going to cost you abit ;) 1k maybe more depends where u buy from and if u get rails or not
realistically its the rails that make the seats go forward or not... if you get bride or recaro rails suited for your car then it will go forward or otherwise you can get a custom ones made from your original rails... either way it should go forward and back...
they are expensive, but they are damn nice seats. Hug really well. If you were still looking at getting bride seats knowing the price (luckily mine came with 2 brix) I would go for the Brix II :P
A cheap option is OBX. They come in pairs and are half the price of a single Bride. The OBX Monaco Sports is very hugging.
im a bit of a stuck up prick and only like buying the best brands, its kinda my downfall lol
lol... well they are very good seats (the bride brix that is). If you have the money to spend...get them ;)
Nengun have the Bride Brix II Entry for just over $1100 delivered and the Bride Brix II for just over $1200 delivered. :D
That is per seat...the rails are extra. About $300 delivered per rail
per seat, are you sure, ive seen like that for 2
are you sure? if you are let me know where coz I will replace my Brix I's for Brix II's :O
Everywhere I have seen it's per seat. You will find the same for Sparco and the other top brands...per seat. For 2 front seats and a pair of seat rails you would be looking at close to $3K
www.modyourcar.com.au also have Bride Brix II for over $1K. They mention when they are sold as a pair as per OBX...doesn't mention pair for Bride.
You can buy decent brix second hand for $800 each or less. Have seen them for as little as $300 if they badly need a retrim. Rails from around $150 each.
Look around, you may even get luck if you find some in a wrecking yard and they dont know what they are worth (mate picked one up for 4250 with rail in perfect condition - no they dont have any more :P)
Another option, C-Red are selling some very sexy looking East Bear seats brand new at good prices http://www.silviawa.com/forums/index.php?showtopic=14408
Hey Steve, do you know of any good trimmers in Perth? Mine need retrimming as they are faded, and the bolstering is starting to get a little soft. Do you know if they can retrim it like the original with bride written down the seat?
Ta JB
Sorry JB,
I believe the material is almost impossible to get hold of, I have only ever seen it sold to suit door trims and glove boxes, never large enough peices to do seats. Even the side/back material is not sold sepeartely AFAIK.
And I dont know of any places to get retrims done in perth sorry, but I am sure there are others on here that will.
Thanks anyway steve...might mean I will have to replace them. Had a patch done when I first bought the car and was very disappointed in the result. The material didn't match properly and neither did the colour...might be able to sell them I guess, or I could get it retrimmed in a standard black material and get Bride embroided on the top. Had a look at those East Bear seats on the link you posted. They look pretty good.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
