As some of you may or may not know - Satanic - R34 gtt, myself - R33 SII and Doodz - R33 SI went to a dyno day..
We all managed to dyno within 2kw of each other:
Satanic: 156.0rwkw
Myself: 156.5rwkw
Doodz: 158rwkw
Now I thought - "shit that's alright - running pretty close for reasonably stock cars"..
The only problem with this is that Satanic's car is an R34 gt-t running @ 10psi which should give it a atleast 10-20kw more than mine and doodz's car..
From this I checked out our dynos and noticed that the peak of the curve was @ pretty much 180kmph - or as some of you know the speed cut off for R33 and R34 gts-t and gt-t's..
I than went and checked out the datalogging from my car when I had the consult cable in and noticed that my car reached 180kmph @ 5,500rpm - and flat lined from there to redline 6,800rpm..
Could it be possible that what happened is our cars all reached the same power level @ 5,500rpm or 180kmph and than the power dropped because the car was no longer accelerating as it was at it's speed limit?
There was a second R34 gt-t there that ran 170kw pretty much stock - this would be more inline with a 208kw RB25DET NEO engine - which is what satanic has.. I've got a feeling his speed limiter had been removed as his car had what looked like some slight changes in the engine bay - but running stock boost..
Thoughts people.. I want your thoughts..
What level in shootout mode did people dyno @ in their stock R33/R34's..
cheers,
Links
https://www.sau.com.au/forums/topic/85870-speed-limiter-and-dyno-results/
yeah, if you were reaching the speed cut the line would just stop dead. mostly i have found the nissan speed cut sometimes come in as late as 190 odd kph even with stock size tyres and wheels. when you go to bigger wheels you can go faster still before the cut.
your graph starts going down before your car hits 180, and yeah even running 1 bar on the stock turbo my car keeps increasing power till 6200rpm where it stops because the turbo can't supply more air, so i dunno why yours drops off so early, there is still 1500rpm before redline, shouldn't be dropping off so fast so early
hey fellas.
in just reading about the speed cut.
one lonely day on the highway, i wanted to test to see what this speed limiter did.
ive ben in some cars where, the engine stop putting power to the wheels, and the rev gauge dies down quickly.
however when i put my foot to the floor, the needle was pretty much verticle (bout 220 km/h), and the car didnt want to stop at all.
so waht is that spose to mean? has the limiter been removed? i have 19's, iv'e heard bigger wheels can mess with it??
sorry to be off topic...
rgds, Dave
it either means the wire is cut as stated, or your speedo is out.
I'd place a bet @ speedo. I could get a fair way around 180 before i got a cut
no, once you hit the speed limiter its hardly going to increase in RPM
if you dont have a limiter than thats a different story
Depends where the speed is being taken from too.
I think the ECU should be ok though
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
