Hey,
My 32 GTR always idles at 1100 rpm
dosent matter if its just been started and its cold, or if its completley warm, or if aircon is on or off it will only idle at 1100
just wondering if this is normal?
i havent touched the idle adjust since ive had the car on the road, which hasnt been long
https://www.sau.com.au/forums/topic/85873-quick-idle-question-r32-gtr/
Do you have an aftermarket ECU? You might and it might not have a/c idle compensation etc.
Check your air intake for cracks or small holes in the pipe from teh filter to the engine. If there is a whole or leak then the car compensates by kicking up the idle.
also, my engine temp guage goes up really fast when i turn the car on before it sits at operating temperature, like from cold after say 2km it will be at a stable temp on the guage and stay there about 3/4 of the way up, but dosent go above this
I was looking at the manual and it says the engine temperature signal can cause idle problems, could a faulty engine temp sensor cause these problems?
i had a really weird problem with mine.. the lines on the carbon canister (behind left hand head light) were on back to front, causing an air leak and high idle.. try swapping them around ( the two larger ones) see how u go.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
