Installed this last night...  had some trouble locating all the grounding points but I got there in the end.  Tested it out this morning and can definitely see differences - the voltage meter doesn't drop anymore no matter how many buttons I press at the same time!
Also noticed a little bit more ummpff down in the bottom gears - could be misconception.  Have a shitty tape deck right now so no idea whether radio booms more; and as for lights - no lights during day time :P
Question:
The LED on the unit is always on, even when the car is off...  this will have absolutely no chance of draining the battery yeah?  I know this is a dumb question but just to be safe.
Finally, talked to my mate this morning and he explained how it works...  the unit is just packed with capacitators which hold voltage from the battery.  Whenever there is a dip in the power curve (electrical), the unit will release charge and keep the curve pretty much flat.  This explains how everything related to the electrics keeps running high if not "higher" since there is no drop in voltage.
Sorry if I've repeated any information before.
Will post photos of my install on my site later on.
Thanks again Greg
Hi mate, glad to hear you are happy.
If there is anything else I can help you with please feel free to contact me.
P.S please post pics up here or email to me once you have them. I would really appreciate it.
Cheers,
Greg Kruse - GK Technologies
www.gktech.com.au
  • Replies 45
wow.. that's a lotta wiring! I hope you don't have to remove your strut-brace any time soon ;op
Good to see your FMIC went well! (came round to buggy repair place to see it going in)
Not supposed to talk in here but hey thanks... and the strut brace won't be coming off, it's better than anything aftermarket anyway. Thanks for coming around last time too...
FREE BUMP FOR GREG KRUSE
Thanks heaps for the pictures mate.
If there is anything else I can help you with please let me know.
cheers,
www.gktech.com.au
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
