just wanting some peoples advice with removing the rear wing on a s2 r33. i have removed the two bolts from underneath and am not quite sure whether the stuff holding it down is the dreaded sickaflex or another type of adhesive.
if anyone has some tips on how to counter this problem it would be much appreciated.
thanks
https://www.sau.com.au/forums/topic/85903-help-with-rear-spoiler/
ive undone EVERY SINGLE ONE and my win is glued on or some biz... its seems like a strange wing too.. it doesnt have a brake light and is really quite large stands about 15-20cm in the air... anyone know what type of stock wing it is cause its still has the stock bodykit...
lol....i tried to do it once.........spent two hours trying to figure it out.......ended up almost removinf the complete boot lid........but the wing just won't come off.........sme one do a DIY guide would be nice
  • 3 weeks later...
removed mine about 2 weeks ago. Man that thing is not going nowhere after being there from the weather in japan.
There are 4 bolts from memory and a couple clips,. Thats the easy part.
Mine ( and probably all ) was glued down with some sort of sikaflex urethhane to stop water leaking in the holes. It was a bitch and a half to remove. Just get a stanley knife blade, and try scrape under the wing. BE VERY CAREFUL not to stratch the paint. Also use a heat gun to heat up around the glue. You have to use a fair bit of force and eventually it will come off..
Goodluck !
