Hi every one,
I am looking to up grade the AFM's on the GTR and I not to keen on getting second hand ones that may give me trouble shortly. But in the same breath, I dont want to cough up the $750+ each that nissan want for the genuine RB25 AFM's.
as im only looking at making about 300-350rwkw the RB25 AFM's would be sufficent, but will go with what is best at the time.
Just wondering if any one could answer a few questions I have?
* Dose any one make after market or equivilent of the RB25 AFM?
* Dose'nt Bosch make the Z32?
* Dose any one have part no.s and/or prices for RB25, Z32, NISMO etc. air flow metres?
Cheers, Mark
Edited by mark morris
https://www.sau.com.au/forums/topic/85933-air-flow-metres/
I was in the same boat but just bit the bullet and got z32 brand new. Not cheap but new. I even changing the airflow meters don't go rb20/25 meters. Sure they're 80mm but bugger all difference in electrical callibration. Same with Nismo 65's(They are supposed to be rated at 700ps a pair-crap).At 330kw at wheels my GTR maxes air voltage around 3.5v. Plently more left and sill idles good. Gotta chop/replace the plugs though and get 80mm z32 specific gtr filter kit (eg Apexi super suction) Prices each I've checked:
RB20/25-$200 s/h
Z32-$250-$450 s/h or $600-$800 new
nismo-$400 new
My advice is to stick with stockers until you max them out on the PFC then get z32 units, unless you get the rb25 ones for a really good price(they plug straight in). Depends on how much kW you are stopping at.
350kW rb25 afm will be close to max.
https://www.sau.com.au/forums/topic/85933-air-flow-metres/#findComment-1555813
Thanks for the good info fellas!
Ken, long time no speek. Are they from bosch?
Hey did you get that black r32 you were waiting on last time I was over there?
Yes they are from Bosch and yes , the black GTR is here.
Runs 407rwhp off the boat at 15psi :P:D
Cheers
Ken
https://www.sau.com.au/forums/topic/85933-air-flow-metres/#findComment-1556172
nice, mate whats done to it? Well have to get both of the black bangers together for a photo somtime.
I Got a part no. off a second hand one here: F00E000202.
Dose any one know if this is correct, and dose any one know what resistance I should be getting across a good one?
https://www.sau.com.au/forums/topic/85933-air-flow-metres/#findComment-1556220
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
