Nozila Posted August 31, 2005 Share Posted August 31, 2005 hi guys, can anyone recommend a place that does a good job at wheel alignments and balancing at a resonable price. cheers, duc. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/ Share on other sites More sharing options...
prof_dls Posted August 31, 2005 Share Posted August 31, 2005 I had my series 2 wheel alligned (all 4 corners) at Action Suspension (on Deloraine Ave, Edwardstown off South Road) and was really pleased with the job and the customer service. Cant tell you off the top of my head what the price was but it wasnt anything rediculous. Good luck Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1555708 Share on other sites More sharing options...
Bl4cK32 Posted August 31, 2005 Share Posted August 31, 2005 north - i think pedders on G.Grove rd seem to be good. Guy there reckons they can setup your car up (camber/caster/toe) for what u want ie Mallala/drift etc... Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1555979 Share on other sites More sharing options...
Deluxe Posted August 31, 2005 Share Posted August 31, 2005 Hey Duc, Dave at Wheelworx on South Rd can do your balancing, but for wheel allignment and balancing i would reccomend you go see Scotty at AVS in Edwardstown, he does all of Markys stuff and Johny Jspec and a heap of the drifters, does good work! Darren Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556128 Share on other sites More sharing options...
Nozila Posted August 31, 2005 Author Share Posted August 31, 2005 thanks darren, ive got AVS's number and address here but i dont know what their prices are like (probabrly best to ring myself and ask i know). although seeing as they have market themselves as specialist in drift/street and what not indicates to me that they "may" be expensive. btw the camber on the front is very out of wack, does anyone know if they can you adjust to as close to 0 as possible without aftermarket components. as my sil80 currently has stock shocks but not stock springs and its causing my the front cambers to be rediculously out of alignment. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556226 Share on other sites More sharing options...
Busky2k Posted August 31, 2005 Share Posted August 31, 2005 You cant adjust the camber on the front without using an aftermarket bolt kit. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556319 Share on other sites More sharing options...
1400r Posted August 31, 2005 Share Posted August 31, 2005 Hi Duc its probably in part due to the GAB swaybars (if you still have them fitted) I remember when I put them on it cambered out the wheels a fair bit. Id be happpy to swap my stock 32 ones over if you'd like they should fit? he he Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556323 Share on other sites More sharing options...
Nozila Posted August 31, 2005 Author Share Posted August 31, 2005 hey matt, how you going mate? it isnt the rears, its the fronts as they have quite a bit of negative camber on them. would you believe that it is now one colour? isnt that a surprise. btw, you should come on a skyline cruise sometime since spring is here, would be ideal weather for it. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556337 Share on other sites More sharing options...
Nozila Posted August 31, 2005 Author Share Posted August 31, 2005 You cant adjust the camber on the front without using an aftermarket bolt kit. <{POST_SNAPBACK}> yeah thats what i though. i might need some stock springs to see if it rectifies the problem by any chance. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556339 Share on other sites More sharing options...
Sambo33 Posted August 31, 2005 Share Posted August 31, 2005 you really shouldnt pay more than about $30 for a wheel alignment, most places do it in about 1/2 an hour for all 4 wheels. one place tried to charge me $110 for a wheel alignment after some suspension work, i was quick to tell them i would be taking my business elsewhere Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556461 Share on other sites More sharing options...
Nozila Posted August 31, 2005 Author Share Posted August 31, 2005 i payed ~$40ish at the tyre place in the city across from stratfields a while back. and i think that was with sau discount too, supposively. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556487 Share on other sites More sharing options...
1400r Posted August 31, 2005 Share Posted August 31, 2005 (edited) "hey matt, how you going mate? it isnt the rears, its the fronts as they have quite a bit of negative camber on them." yep I know the front has a upgraded swaybar too. "would you believe that it is now one colour? isnt that a surprise." sweet glad to hear it my skylines becoming a bit of a drift pig now "btw, you should come on a skyline cruise sometime since spring is here, would be ideal weather for it." sounds good any sideways action happin soon? I should have my power up sorted by then Ive already stuck the 2530 on just getting the cooler fitted this week Im hoping to make around 170 till I get a remap and injectors then Im chasing 220rwkw sic hows the 33 going? what sort of powers it making now? Edited August 31, 2005 by 1400r Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556572 Share on other sites More sharing options...
Nozila Posted August 31, 2005 Author Share Posted August 31, 2005 33 is in the shed with some electrical issues, nothing major. 2530 on rb20 with a target of 220rwkw's? that should be achieveable given right supports im sure you know this anyway. friend has same turbo on his rb25 and it made ~260 rwkw's. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556688 Share on other sites More sharing options...
mr_rbman Posted August 31, 2005 Share Posted August 31, 2005 Scotty at AVS will look after ya! Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1556941 Share on other sites More sharing options...
Tangles Posted September 1, 2005 Share Posted September 1, 2005 btw the camber on the front is very out of wack, does anyone know if they can you adjust to as close to 0 as possible without aftermarket components. as my sil80 currently has stock shocks but not stock springs and its causing my the front cambers to be rediculously out of alignment. <{POST_SNAPBACK}> Check out Sydneykids forum on suspension upgrade in the Stagea section - has a deal going at the moment for suspension upgrades for Stages, GTRs and R33's. Decent pricing for camber components... Brendan Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1558016 Share on other sites More sharing options...
Nozila Posted September 1, 2005 Author Share Posted September 1, 2005 Check out Sydneykids forum on suspension upgrade in the Stagea section - has a deal going at the moment for suspension upgrades for Stages, GTRs and R33's. Decent pricing for camber components...Brendan <{POST_SNAPBACK}> i wish i could use them but its for a 180sx not the line. Link to comment https://www.sau.com.au/forums/topic/85976-wheel-alignment-and-balancing/#findComment-1558316 Share on other sites More sharing options...
