hey all
I recently imported a 1990 r32 gts-t. Its very stock and in pretty good nick, except for the following two things. It has 104,000klms on the clock, 100k service done at 97,000. The car runs perfectly. No funny noises except for a bit of tapping from the rocker cover, no leaks, etc.
I'm a pretty experienced DIY'er and know what different colours of smoke mean amongst other stuff.
1. I've been told that when i accelerate hard and then let off (say when changing gears) i have a small puff of white smoke from the exhaust. This is after the car is warm and has been warm for a long time. Can anyone tell me what is causing this? I don't have any other form of smoke coming from the exhaust except for the early morning condensation.
2. I recently installed an A/F ratio gauge in the car. I know they are pretty useless, but the actions of the thing got me thinkin. Under acceleration, it runs slightly rich and doesn't fluctuate the entire time under acceleration However, when at cruising speeds, holding acceleration it will hold stoich for 5/6ths of a second and bounce to very lean breifly for 1/6th of a second and keep repeating that cycle the entire time i'm at cruisin acceleration. It seems like a miss of some sort, any help???
Sorry for the long ass post guys. Thanks for your help in advance.
BTW - i've searched through many pages on the white smoke thing, only to find that people say that "its bad". HOW BAD??
https://www.sau.com.au/forums/topic/86006-bad-symptoms/
Either of those two things will do it. I reckon more likely your turbo is on the way out. It will probably die slowly so don't stress but put some $ aside.
$300-500 should get you a second hand RB25 turbo which will be a nice little upgrade.
https://www.sau.com.au/forums/topic/86006-bad-symptoms/#findComment-1557594
A/F gauge should be rich on WOT and bounce back and forth from lean to rich/stoich when cruising. This is because the ECU is in closed loop and is feeding fuel based on the oxygen sensor readings. It will lean it out till it gets too lean, then richen it up till its too rich. Keeps on doing this hence why you see it going back and forth.
https://www.sau.com.au/forums/topic/86006-bad-symptoms/#findComment-1558226
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
