hey all
I recently imported a 1990 r32 gts-t. Its very stock and in pretty good nick, except for the following two things. It has 104,000klms on the clock, 100k service done at 97,000. The car runs perfectly. No funny noises except for a bit of tapping from the rocker cover, no leaks, etc.
I'm a pretty experienced DIY'er and know what different colours of smoke mean amongst other stuff.
1. I've been told that when i accelerate hard and then let off (say when changing gears) i have a small puff of white smoke from the exhaust. This is after the car is warm and has been warm for a long time. Can anyone tell me what is causing this? I don't have any other form of smoke coming from the exhaust except for the early morning condensation.
2. I recently installed an A/F ratio gauge in the car. I know they are pretty useless, but the actions of the thing got me thinkin. Under acceleration, it runs slightly rich and doesn't fluctuate the entire time under acceleration However, when at cruising speeds, holding acceleration it will hold stoich for 5/6ths of a second and bounce to very lean breifly for 1/6th of a second and keep repeating that cycle the entire time i'm at cruisin acceleration. It seems like a miss of some sort, any help???
Sorry for the long ass post guys. Thanks for your help in advance.
BTW - i've searched through many pages on the white smoke thing, only to find that people say that "its bad". HOW BAD??
https://www.sau.com.au/forums/topic/86006-bad-symptoms/
Either of those two things will do it. I reckon more likely your turbo is on the way out. It will probably die slowly so don't stress but put some $ aside.
$300-500 should get you a second hand RB25 turbo which will be a nice little upgrade.
https://www.sau.com.au/forums/topic/86006-bad-symptoms/#findComment-1557594
A/F gauge should be rich on WOT and bounce back and forth from lean to rich/stoich when cruising. This is because the ECU is in closed loop and is feeding fuel based on the oxygen sensor readings. It will lean it out till it gets too lean, then richen it up till its too rich. Keeps on doing this hence why you see it going back and forth.
https://www.sau.com.au/forums/topic/86006-bad-symptoms/#findComment-1558226
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
