Probably not mate, i have a dumped car on 18's 235s (only 8 inches) and they JUST miss at the rear, so goodluck with your 10.5" rims at the rear. Also at the front, goodluck again, you cant even lower a skyline more then 2.75- 3" on the front with 235's and your 245's that you want will make it even harder.
So, its do-able, you wont be able to drive the car at all though you'll literally have no steering. If your going to do it at all the maximum i suggest would be 235's all around on 3" lowered springs.
Dayne
I know 8.5 inches on the front and 9.5 inches on the rear with a low ride height (not low by most people standards, I'm taking DUMPED - on the rim with 18s / sub 50 odd mm of ground clearance sort of low) is doable. But I wanna know how much further I can push it.
Anyone know for sure?
Edited by [SPESHAL]
like your wrx low? :D
i reckon you can dump it to that level, ive got alot of play with my 8.5/9" front/rear on teins (im at about 90mm now, but the gaurds have a fair bit of room still left in them, and the suspension has a good 120mm left in it :D)
Dayne
Its all about the off-set. You can make 10" wide rims fit and make 8" wide rims not fit, if you have the wrong offset.
8.5" front is piss easy, 10 rear shouldn't cause you much troubles, might need to go some jap drift spec camber to squeeze them under tho, mine has had to have a decent whack of neg. camber to fit under.
sold the rex yet?
glad you've come over from the dark side! :D
,31 Aug 2005, 06:30 PM]As the title suggests, can you go this wide with 18's or 19s on a 33 GTs-T?
I'm looking for the Jap style mega dish, rim close to guard, dumped ride, style....
If so, what sort of offset should I be looking for?
So basically you don't care that the car will handle like shit, ride like a bucking horse, won't stop, and will loose about 25bhp due to the lousy drive shaft angles. You don't want to drive it because it will get an instant defect, HighUndies will out drag you and MB A180's will out corner you. You just want to sit and look at it.
Each to his own I guess.
:D cheers :D
Edited by Sydneykid
Yeah Mitch, I've sold it. Was a good car and wish i didn't have to sell it!
Thanks for your input Sydneykid, much appreciated. ;) I've owned numerous cars with that sort of ride height, daily driven, and don't mind one bit.
The sort of setup I'm looking at is similar to the ex JMS R33, maybe a touch lower. That seemed to handle ok.
Edited by [SPESHAL]
ah k.. yeah they are nice cars, my housemate has a green 95' wrx, you might know him (SIKEM REX).
i doubt you will have too much trouble with driveabilty, mines solid on the road at this height. id like it a bit lower, but ive had enough canary's, don't know how you got away with the bugeye :O
:( cheers  :)
Actually, for drift, from my own experience, I've found that a wider wheel base makes the car a lot more stable, so there is an advantage here in going wide rims with low offsets. My car isn't exactly dumped on it's arse though, I still have 10cm clearance so it's legal height (with stock front bar)
And [sPESHAL] just incase your interested, I had a go at putting some 18x10 -1 offset SSR gartmiers on my skyline, just to see how they looked. SK does have a very good point about DEFECTs it was scary stuff driving past a cop car with this. But as i said, I just wanted to see how they looked, they are stupid for road use...
http://i2.photobucket.com/albums/y19/merli...12/IM000070.jpg
http://photobucket.com/albums/y19/merlinda...nt=IM000081.jpg
http://i2.photobucket.com/albums/y19/merli...12/IM000091.jpg
you could always flare the guards. dont lower it, get bolt on guards as they put the wheel arch in a lower position out further, and then get a deep deep kit like a bn sports or something to give the impression that its dumped.
i too have found the wider rims/increased track better for drift, making the wheel track wider helps to stop spinning, makes it a bit harder to kick out, but easier to hold out there.
i have 18x8+30 and 18x9+35 with 1.5" dish on the front and about 2.5" dish on the rear, i always wanted to step up to 9 and 10" wide, but decent 2nd hand tyres are hard to come across in anything bigger than a 235 which barely fits a 9" rim.
cheers
Linton
okay here's a question for you guys
r33 gts-t
18x9.5 +22mm offset front and rear
275/35/18s front and rear
JIC FLT-A2 coilovers
JIC RUCAs
running 3.0 degrees of negative camber up front
2.0 degrees of negative camber in the rear
front and rear fenders pulled as far as possible before the paint starts to crack
still think they won't fit after all of that work???
Thanx in advance
Late,
Daniel
thanx for the link. i know about the offset calculators already though :)
my question doesn't pertain to whether or not the wheels will fit with that offset......its more of a question of whether or not people think they will fit with that offset AND the fender mods I plan on doing to the car :P
Late,
Daniel
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
