Ok tonight i have removed the exhaust and the apexi exhaust control valve, and found its that apexi device that caused the problem.
i saw 1.4 bar tonight as set on the wastegate. So im very happy, seem to have found the problem.
wil post some more pics and more detailed stuff tomorow.
:P
mick
  • Replies 69
Well it worked!!!
The exhaust conrol valve it looks to me didnt have enough tension on it. with my hands i could quite easily push it closed half way from being open. then it got tuf to push, like you would expect it be. so think it must have been closing up enough under pressure to cause a blockage of sorts.
anyway for now its not in there, will get all the desired boost levels i want with ebc and stuff first, (as i only got 1.4 bar lastnight on wastegate spwing rate) (ihave 1.3-1.7bar spring) then fix up the tension of the thing before refitting it.
so atm i was hitting 1.4 far in 2nd and 3rd gears. but a certain intercooler pipe would blow off. done that 3 times. clamped it up tight as. so will try get some decent clamps today/tomorrow and get on teh dyno next week.
so thats good. here are some pics.
the one with my thumb shows how far it could push closed easily with not much pressure before it got tight.
and just a couple of other pics of the setup etc.
mick
lol
yeah thanks for everyones help! :P
but yeah havent really drivin it since the testing last night, and every full load run the intercooler pipe swas getting blown off! lol damn
so will get some good clamps on it this weekend.
booked on dyno on weds and see how she goes!
fark dude thats an anoying oversight.
well i guess that you and everyone that contributed will know your car inside out if you run into dramas again B)
i bet your relieved now. you shouldnt have to much trouble selling the gate :P
yeah defo.
it was somehting i always wanted to check from the start, but meh im not the best of mechanics and sort of was lazy about doing it thinking it was a looong shot. lol pwned eh!
damn wish I did.
But yeah fixed all piping up today, car is running awesome, hard as nails on 1.2bar (set on boost controller) will go for more boost when dynoed etc during the week, will let everyone know how i go.
im just overjoyed its running sweet now.
thanks everyone.
michael
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
