The best track day you will go to.
Professional in car and pit race driver instruction.
Professional transponder computerised accurate timing.
Biggest collection of GTS-T's and GTRs as well as other cars including one fast zed.
Crowd of fellow enthusiasts.
Drifting segments.
Pro Photographers.
Events and action caller.
$195 to enter. South Circuit.
https://www.sau.com.au/forums/topic/86034-uas-track-day-sunday-25th-septemeber/
GTR Jason, I thought the guy dissapeared? whats his username on here?
guys can I attend even tho I have an EPA defect atm?
You should be fine, most cars on race tracks will never pass EPA inspection(for road use)
Edited by Flaps
John,
Whats the track sheduale look like, ie what drive type and times.
Whats the count how may cars do you have?
Remember, you only have 4 days to not have your boat ready.
Hmm I can already taste that bottle of 707 now.
GTR Jason was my mechnaic for a while on the R32... then he dissapeared and some dodgyass holden mechianic that bought his workshop quoted me $3000 to fix a little problem that I later found was just a speedo needle sticking out of the instrument cluster and controlled everything on the car includign speed, hicas, power steering etc.!!!! Free 5 minute fix against $3000 that would not fix the problem and take forever!!!!!
Not a lot of SAU people there but a great day even though I was only there for 3 sessions.
How did Caroline go in the Silver Zed? Did anyone notice the tyres she had on? :(
Adrian
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
