Hi guys,
I have been offered to buy a package of goods to get my car up and on the road but not sure weather its quite the bargin its cut out to be.
It includes 1 headlight, 2 park lights, and a rear window.
How much would this stuff be worth?
Stuff i need to source still.
Center vent.
and steering wheel.
maybe a stock air box.
Also i have been told a few things about getting my car registered. Its not complyed yet.
I have import papers that bring it in under the 15 year rule.
This means it just has to pass a road worthy. Am I correct in saying that. I did do research before i bought it but a few people have now told me differentally.
https://www.sau.com.au/forums/topic/86079-complyance/
you also need to make it meet the ADR's which involves:
side intrusion bars
child restraints
fuel filler restrictor
high mount stop light
tyre placard
Depending on how much they want for the parts Sam is what makes that a good or bad decision.
Yes you will need those parts for the compliance and sometimes its better to just get them than wait around for them to turn up cheaper.
There are a few little things you have to do, so the car meets complaince for TAS rego under the old 15 year rule.
you DONT need side intrusion bars (so dont listen to anyone that say's you do)
and the high mount stop light does not matter here either (if you got it in the wing then it does have to be operational though)
COMPLAINCE NEEDS:
seat belts and child restraints changed (although you can get the original's certified, but its not really worthe it)
drivers side mirror has to be changed
VIN number has to be stamped under the bonnet (and obviously the import papers have to match as well)
Unleaded fuel only sticker on the inside of the petrol flap and depending on where you go you may need the fuel filler restrictor???? (i didn't though)
all lights have to be operational (stop/brake, indicators and headlights)
all windows (electric or mechanical) have to be operational
no part of the exhaust can be going to atmosphere :P
aftermarket air intake is ok (but again depends on where you go)
number plate lights need to operational
tyres need to meet approval (ok tread left, no cracks/splits in side walls)
battery fasterner
and thats about it really.
if you need a hand with anything then give me a yell.
also i know a few people that can help out with getting the car road legal with your inspection if you like :D
Cheers B
https://www.sau.com.au/forums/topic/86079-complyance/#findComment-1557769
im not sure ive seen alot go to the trouble of putting the side intrusion bars in....
why do you need a pack for lights and stuff sam?
you dont need side intrusion bars but some peeps in the complaince game will tell you that so they can make a little more money out of you :P
I believe Sam needs the lights as his car at the moment only has one head light?
https://www.sau.com.au/forums/topic/86079-complyance/#findComment-1557771
I dont know about TAS, but in SA you have to get intrusion bars fitted, as well as a engineers report so they can verify the work.
yeah its not really needed here in Tassie, although the rules are about to change again.
The beauty of it is, its getting easier and easier to register an import these days and its not costing as much either :P
Try going to Vic or QLD as there some of the hardest places to get imports complainced <_<
https://www.sau.com.au/forums/topic/86079-complyance/#findComment-1557834
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
