It's the traditional whine sound from all the speakers which rises in pitch when you accelerate/rev the engine. What are the measures i need to take to get rid of it?
I've got an Alpine CVA1000, EQ, 4ch Amp, and stacker... the stacker, eq and headunit are connected via Alpine's Ai-NET, and from the eq to the amp it's RCA's. The RCA leads have a ground cable at each end which i presume grounds the shielding. I don't think there is a noise filter on the alternator (so i spose i should get one of them to start with), I do have the power cable running next to the RCA's due to the difficulty of placing them separately.
The sound happens on all sources eg radio or cd player.
What measures can i take apart from moving the power cable to the other side of the car and putting in an alternator noise filter (actually, what type is the best one to get, and how big?)
Thanks,
Andrew
https://www.sau.com.au/forums/topic/8608-loud-buzzing-sound-alternator-whine/
the earthing of what? the amp? Cos i sanded the metal surface back that it was going to touch to make sure there was good contact. RCA's cost me $40 each... so i would expect them to be decent.
What about the size of the Negative Battery cable? should i perhaps replace it with a bigger one? like a 4ga cable?
Try earthing it in a different place, sometimes if u earth it in a certain spot you can get engine noise
(yes the amp earthing)
may be a good idea to check FAQ's at www.caraudioaustralia.com
is most likely to be either poor earthing or a poor contact/connection somewhere - make sure all your terminals are secured well and have good contacts.
also i hope you aren't running the headunit, stacker & amp all off the same power cable - it is best to run amps on seperate cable.
is your battery in the boot? if so, try running the amp straight off these terminals.
out of curiosity, what size power + earth cable are you running?
I sort of found the problem... i have the excess RCA cables bunched up and cable tied in the boot, the power cable from the battery (i have one for each amp, 8ga for both the power and earth). I moved the RCA's a little and the noise went away... and since putting everything back in the car it has come back a little (not as loud as it was)... grrrrr... so i'm gonna chuck a supressor on the alternator to see if that does anything to remove the little bit of noise, otherwise i'm going to have to pull out the back seats again and see if i can relocate the bundled RCA leads.
  • 3 weeks later...
hmm i got that noise too, but before that my sub always popped, when i tore things apart i found out that it had been earthed on an area with a thin layer of paint. so i scratched the paint off a lil and re-earthed and the popping stopped... now all i have to do is get rid of the whine.
Nah, haven't had time to sort it yet... mine are in the RCA's, they are running a little close to the power cable.
Perhaps check your RCA's from the deck to your amp (if you have them), if not, then i don't know how to get rid of the whine... perhaps put a supressor on the alternator.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
