Bridgestone Re55 Prices From Donnellans Box Hill.
Hey guys,
Mark Donnellan has asked me to update the discounted prices for Bridgestone RE55's. The price has increased slightly for some sizes. If the size you want is not listed below, contact Mark to enquire and mention Skylines Australia.
Since the other thread was closed I've started a new one with the current prices. DO NOT WHORE THIS THREAD.
Details:
Contact Person: Mark Donnellan
Donnellan's Box Hill (Bridgestone Tyre Centre)
837 Whitehorse Road, Box Hill
Ph: (03) 9898 9591
Melway Ref: Page 47 B9
UBD map ref: Page 256 N14
Prices:
[ 18" tyres ]
Bridgestone RE55 225/40/18 . . . . . . . $376 per tyre
Bridgestone RE55 245/40/18 . . . . . . . $383 per tyre
Bridgestone RE55 265/35/18 . . . . . . . $418 per tyre
[ 17" tyres ]
Bridgestone RE55 235/45/17 . . . . . . . $348 per tyre
Bridgestone RE55 235/40/17 . . . . . . . $351 per tyre
Bridgestone RE55 255/40/17 . . . . . . . $375 per tyre
Comparison of tread pattern between older Bridgestone 540s and current Bridgestone RE55:
Enjoy B)
Cheers.
Mate I don't think you can really compare the Direzza DZ101's to the RE55's.
If we're comparing road tyres, I'd put the DZ101's against Bridgestone S03's, and I'd still prefer the bridgestones because they're damn good tyres!
But if we're talking R compound semi-slick race tyres, I prefer the RE55's over Yokohama's or any other brand.
oh derr im a retard i didnt realise the Re55s were like semi clicks. my bad sorry i thought they were one of the sports range tyres. jeez i feel like a retard haha
Please don't hide this away. I had terrible trouble finding the old thread last time I went looking.
It's cheaper for me to use your connections and ship them to sydney than it is to buy them here with a club discount from a club sponsor, let alone from any other shop up here.
It depends - but not ages.
Put it this way - I usually do say 10 track days a year and go a for a number of spirited drives but otherwise rarely use my car and I still go through 2 sets of these a year.
But without track days I'm guessing 10,000-15,000km's only.
I've had them for 1.5 track days and around 6,000 kms total road use.
I wouldn't expect them to last any more than 3,000 kms of road use plus a track day.
Oh and they're a very noisy, tramlining, irritating road tyre. If your car doesn't hit the track then I would spend a few more bucks and get a good road tyre (say ContiSport Contact 2s or Michelin Pilot Sports) that are simply awesome on the road and will last 30,000kms
thanks matt do you know how the compare against the dz101's
Sorry ot get off topic paul i don't know what rims size you hav but Dz101's in 225 50 16 and 235 or 245 35 r17 have been discontinued so this means the 16" version have dropped to $220 ish from $300 mark but if you go to a beaurepairs or anyone with big dunlop dealership you can get them for a good price :cheers:
but yest can't compare to re55's
  • 4 months later...
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
