OS Giken Triple Plate clutch to suit R32 GTR
In Excellent Condition.
Clutch Plates 90%.
Fitting Available.
Must Sell Asap
$1400 But am open to all offers
Located in Dandenong Victoria
Any Questions please Call Lee on 0403-130-313 after 5pm Weekdays or SMS your phone Number anytime and I will get back to you ASAP.
Thanks.
https://www.sau.com.au/forums/topic/86193-os-giken-triple-plate/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
