I hope I better my previous PB of 15sec flat!... (stock)
...well I should as my car has another 80rwkw and 100mm more rubber under the bum...
anyone else going down for a run tonight? if you see a silver R33 gtst with AVS 5 spokes and a really loud gunmetal R33 gtst with Nismo rims come say hi!
we will be the unshaved suss looking characters wearing 4 jumpers and beanies... oh wait that describes everyone there! ... hope its not too bloody cold... good for the car, bad for me :P
https://www.sau.com.au/forums/topic/86241-calder-tonight-2905/
Yeah ill be heading down, not Skyline affiliated though!
My brother has a Blue HQ with a big F**K off engine in it... She doesnt look real pretty at the moment (body wise) but she should run a mid 11 tonight and he can pull a mean skid aswell - he has won the burnout comp quite a few times.
Soon the engine will be coming out in favour of a forced induction Chev with a big HP nitros setup. And we are also painting the car VB can green with an ice pearl over the top.... should look the goods.
I will be cruising around wearing a HSV jacket so if you see me aswell please say'hello.
Good luck Nick. Hope all goes well for you mate... See you tonight
ha ha its real hard lining up against some of those old school V8's and rotors that run 11's... can't even hear my car! a couple of times I have reached for the ignition only to discover its already on! staging and then waiting for those big loud bastards to take off so I can concentrate on my launch!
... hey is there a better way to block off the coolant overflow bottle without just tying a knot in the rubber piping?... I lost a lot of coolant last time...
when i went to the drags (heathcote with a ford club) they had to put a coke bottle in there for the overflow, so that the coolant didnt drip on the track....if thats what ur talking about
Well thanks for the "early" notice :P
Here i am, at home, waiting for my mate to finish working at Calder, when i could have been there, having a few runs with you guys :) .
Lately i have been considering taking it down, to see how much of an improvemnt the car has made since last time. Now i will have to wait another month b4 i can test it, as it is getting a few more performance tweaks.
ohh well, have a great night and post up your results.
Al
its ok Al... i think its about time another SAU drag day was held... hasnt been one for like...
FOREVER!!
man i still had my 32 back then and it was stock!
maybe wait til my new skyrines here so i can feel like one of the family again :P
just got back... and my ears are still ringing from all those big cube engines with no exhaust!
best was:
13.75 @ 103mph with a 60 foot of 2.2sec
getting some axle tramp, found it hooked up best with gradually feeding the throttle in after launching at 3000rpm... would have like to get a better 60ft time but oh well its still a pretty good time for stock turbo and ecu
time for beer
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
