  • Replies 129
Posted Images
Oh no, I actually did the stereo first. :(  :)  :)
:) cheers :)
;) Im not sure I want to believe that SK!! :)
Now I know how Luke felt when Darth had a 'father to son' chat with him in SkyCity....... hahahahaha :lol:
Sweet - how many Amps & Subs did you fill up the wagon space with??!!
Brendan
:)  Im not sure I want to believe that SK!!  :)
Brendan
Hahaha Brendan :lol: , I wasn't pulling your leg. I used a Nakamichi head unit with a 120 watt per channnel 4 channel SoundStream amp and 4 X MB Quart coaxials (one in each door). No room for sub's though, I need the rear space for race car stuff. Load carrying is the main reason why I got a Stagea in the first place. That, and its ability to tow the race car.
Sound is good, no doof doof in my Stagea. :D
:) cheers :)
:) cheers  :)
No drum'n'bass then?... Oh well, each to their own hey!! Thats all I really listen too- not into the lyrics and electric (air!) guitars, Kiss style face paint and the like :)
Yeah, the stag boot space is for using, not clutering up with sub-boxes and the like. Mines for the increasing family (read prams and dog), and towing the Fireblade to Mallala (just got to get a towbar and a trailer first!). Hopefully I can install an amp under one of the seats and just use good speakers thru the doors, maybe a small sub into the rear floor..
Good stuff. Anyways, I reckon your suggestion re: fuel lines is apt, so Im going to get that part all organised (fuel pump, nismo fpr, beefy lines etc + the z32afm I already have), and set up some dyno time with GWW to recalibrate the SAFC. No big injectors for me then.
Then save for the never-ending further mods. Brakes first, then turbo. Then suspension. Or as the funds allow. <_<
Cheers, Brendan
hey mcchook
what size co-axial's did you use in each door, as l'm not sure what size splits to get for the front, and what size co-ax's to get for the rear to add a bit of bass.
Also where did u mount your amp, didn't happen to mount it under the passenger seat did you?? As l'm hoping ot mount my 4 chnl amp there
My God, this threads fantastic! :)
:D  :lol:  :lol:
Yeah, SK is just so imformative; Im really glad he's been able to contribute so much to these various threads. Makes fantastic reading, and Im sure a lot of members have been able to gleen a lot of information from SK. I certainly have, so a big Cheers to you mate.
Sweet... Brendan :)
Thanks SK. :)
Now, in regards to the CGC High Flow, what is the MAX they are good for atw's? Is it possible to get 250-300atw's? :)
Cheers,
Chris
GCG emailed me and were reckoning 220kw no worries, so I guess its a matter of fueling and cooling to get that bit more, or perhaps a bigger turbo (really, I have no idea!! - thats why Ive been asking some questions :D )
Cheers,
Brendan
I put the amp in the space where the CD changer was, LHS rear 1/4 panel. The ATTESSA reservoir is in the RHS one.
The MB Quart are the DKE116's , HUUUGE improvement over the 15W Clarion twin cones that were there standard. The MB's are 165mm diagonal between the mounting holes and 180 mm total diagonal. Bit tricky to fit as the MB's are perfectly round and the standard speakers are a rounded off square.
:D cheers :)
Edited by Sydneykid
Thanks SK. :)
Now, in regards to the CGC High Flow, what is the MAX they are good for atw's? Is it possible to get 250-300atw's? :D
Cheers,
Chris
The 250 rwkw is not a problem. The R34GTT makes 265 rwkw with a GCG ball bearing high flow (11.9 at 120mph), best of all it has more power EVERYWHERE than when it was standard. Ian has the same on his R33GTST and he is up to ~270 rwkw. The big winner is the average power, it is very strong from 3,500 rpm to 7,500 rpm.
I don't think anyone will get to 300 rwkw though, that's a pretty big ask.
:) cheers :)
OK, so how would  go about getting 250kw at all 4's using this turbo? :unsure:
It's not the tubo that is going to limit you, it is the ECU. I haven't been able to get an RB25DET much over 225 rwkw with the standard computer and using piggy backs. The compromises just get too much to tune around.
Other items are easy;
Tomei 256 Poncams
Split dump/engine pipe combo
3.25" exhaust with a real high flow cat
Adj exhaust camshaft pulley
(Maybe one of Bass Junky's adjusters for the inlet camshaft as well, but I haven't tested mine yet)
Pipercros panel filter in the standard airbox
S15 JDM manual injectors (444 cc's)
R32/33 GTR fuel pump
R33/34 GTR intercooler
Z32 AFM
Unfortunately that's the problem with wanting more than ~210 4wkw, everything needs upgrading. So the cost of the extra 50 4wkw is very high. That's why my target is ~200 4wkw, it is a very economical to achieve power level.
:D cheers :)
:O
Tomei 256 Poncams
Z32 AFM
:D cheers  :(
Thanks for the advice, SK.
Cheers to you.
Brendan
:unsure: Fantastic SK! Your a credit to yourself :(
http://www.skylinesaustralia.com/forums/in...showtopic=87663
a thread from the forced induction area of this site.... under $1200 for a hks type turbo; and in fact the turbo bigdatto is talking about I ws seriously considering bidding for!
Glad to hear there is at least 1 satisfied ebay turbo buyer out there, who has a recommendation. I think that might almost 'prove' that there are better value for money options out there than a 2grand hiflow job (sorry, I just cant get over why its so expensive to alter a standard turbo, when you can buy new ones for less).
Just my 2c worth. I'll seriously consider using this ebayer for a turbo... at the end of the day you just have to trust the seller that they are selling you a good product.
Now, big questiuon to ask yourselves; is that 'trust' worth a saving of $800...? (ie $1200 for hks2535 or $2000 for hiflow option) <_<
Brendan
Brendan
Hi Brendan, you are not comparing apples with apples here. I can't speak about other high flows, but GCG use a brand new dual ball bearing core, new (larger diameter) shaft, new seals, new gaskets, new compressor, new turbine, machine the standard compressor and turbine covers to suite and them micro balance the whole rotating assembly. It's basically a new turbo, everything that is subject to wear is brand new. All the components are covered by Garrett new parts warranty.
It bolts back up exactly as it was when standard, everything fits, no mods, no extra parts, no missing bits, no days waiting for stuff to be made, just bolt it up up and drive away. That is simply not the case with an aftermarket turbo. You will most likely find yourself spending hundreds of dollars more buying and fabricating parts to get the off the shelf turbo to fit.
You can of course buy a turbo with a fitting kit for an RB25 (GTRS for example) but they cost ~$3,200 by the time they get here. That's a valid (total) cost comparison.
:wub: cheers :wub:
Edited by Sydneykid
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
