Id like to know then how to 'maintain' a bush-bearing type turbo tho - ie do I let car cool down 2min after EACH drive, change oil every 2000kms etc? better check howthingswork.com. From what I gather you gotta make sure it has a strong clean feed of oil, the cooler the better. How can you assure that?
Oil cooler, wouldn't run a plain bearing turbo without one. Plus Castrol Edge 10W60 (or equivalent) to handle the extreme temperatures in the turbo plain bearing. Make sure you cool the turbo down, not idling in the garage/driveway with a turbo timer, drive it slowly, extra lap of the block.
;) cheers :huh:
  • Replies 129
Posted Images
Cheers Gary, thanks for the info. Definately getting an oil cooler kit and a perhaps an oil pressure gauge. Yeah, last 5mins of the drive = no positive boost pressure; got to teach the wife now :laugh:
  • 8 months later...
mate has a standard rb25 in his silvaline - stock everything including ecu except for a 3037 pushing just under 1 bar and got over 275rwkw. You can get the whole thing for the price of a highflowed vg30 turbo - so might be the go when i get to that stage :laugh: and you can push the turbo to 25+ psi so think of the potential :ermm:
ANY of the HKS bolt on turbos gt35/25 series for RBs, will bolt right on
and you can find them on YAJ for 400-800 used and in great shape
they will be good from 250-380 HP with supporting mods (depending on which series you chose, they make 4 that bolt up i believe)
  • 6 years later...
Afternoon All
I have a S1 Stagea RS4 Automatic with an RB25DE, i went to a place today to enquire about converting it to a turbo and they advised that it couldn't be done without having a manual conversion first.
Can anyone confirm whether this is correct or not?
I know for sure that there were Turbo versions, is it not a case of an engine swap??
Afternoon All
Definitely wrong. Where are you? In Auckland go see Joe Kyle... he has added turbos to heaps of RB25DEs
or just buy this:
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/engines/auction-653928499.htm
I thought so, and the weird part is these people are supposed to be a good place to go. I know Joe I'll go and pay him a vist me thinks and see what he can do. Quick question since your a kiwi in the know, Manual conversion here in Auckland know any one who does them and approx cost?
Joe did mine - depends on how much work you can do yourself and how cheap you can source the parts - I got all the parts cheap from a guy wrecking an R33 GTR so total cost was around $2K I think but could be as much as $3k or more. Maybe save yourself the hassle and look out for a manual turbo Stagea - they are not too dear these days!
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
