I have a HR31 Skyline fitted with a RB25DETneo and I'm in the process of having more work done to my car, this includes a custom front entry intake plenum and having the HICAS rear wheel steering locked out.
My question is, on the drivers side of the engine bay there is what looks to be a valve sort of thing that is connected to the steering rack and to lines that head off to the rear of the car for the HICAS obviously.
Now to the more technically inclined people, seeing as I am getting the hydraulic rams on the rear rack replaced with solid locking bars, would it be safe to remove the valve thing and associated lines from the side of the engine bay and just block up the feed and return holes in the rack. To me it looks as though all this device would do is control how much fluid goes to each of the rams at the rear.
Basically the main reason I want to know if it can be taken out is so that there is more workable room for the plenum. I also am using the standard RB25 power steering pump so I'm thinking I should even be able to swap my steering rack with an aus spec one and do away with the entire HICAS system.
I also have this posted on the R31 Skyline club but I thought I would try here too to see if anyone has played around with the HR31 HICAS system before.
https://www.sau.com.au/forums/topic/86270-hr31-hicas-question/
answered ya own question there dude! Thats the best option really, as from memory the rack itself has the feed lines to the rear rams, that valve block with the electric solinoid in it is just the means to control the flow. also the aus rack is probably about 1-2kg lighter than the jap hicas one so there should be no question! :P
also as for replacing the rams, i've done this on my gts-x and its all good but still allows a small amount of east-west movement, i think the best way would be to remove the member bushes and get solid rubber or noly ones made up, like the gibson one. ie:
Edited by kwazza11
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
