  • Replies 50
It was anything but that actually
there was some of that around, but some of the talent getting around was insane
I wouldn't go again though for a few reasons, such as asshat organizers (Right Mick?)
Edited by Bluprint
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1591060
there was this one chick that he thought was a girl.....but lets just say she had an awefully big adams apple for a chick, It was a good disguise though Beau!
I almost fell off my chair after reading that, cos I know what REALLY happened to Mick! :lol:
(tha bastard)
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1591300
It was alright, played to much on the 70's thing and didnt give the great dj line up enough time, but after putting away a bourbon or 10 i didnt seem to care to much. Id go again. next one in either may or march (may me thinks) next yr. Hopefully they will have different MC's at the next one, that big brother guy was a dick
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1593850
Yeah he was a bit of a cockster
looks like he was high as a kite (probably was).... it was kinda amusing watching him try to navigate across the dance floor (which was largely empty at the time)
I thought Cabin Crew were alright
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1594229
I would say shit all shit, the line up sucked the first DJ couldnt mix piss and crap in a toilet if he was sitting on it, the band may as well have gone home. The last DJ was good or maybe i had just drank my share of crap drinks, the chicks were mostly hot but with the same old pathatic attiude oh you dont look rich or wog to me. Oh the food was found in some tip somewhere then served to us in old style chinese boxs but none of the food was anywhere near chinese.
All in all i dont think ill ever be going again and there lucky i dont right an abusive email wanting my money back
Oh the venue was great but thats it
Edited by race_snooze
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1594260
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
