im about to put my car on the dyno. right now my spark plugs are gapped at .8, but i fixed my coils (sanded the inside of them) over 2 months ago and havent gotten one single misfire since. i want to know if i can re-gap them to 1.1 to allow for a bigger spark. i'll be running 14psi on the day.
also, what are some things i can look at before putting it on the dyno?
https://www.sau.com.au/forums/topic/86302-tips-for-dyno-runs/
do you run 14psi on the street? if your on the stock turbo its the sure fire way of killing it, the heat generated by it will kill the exhaust wheel and i doubt it will make any more power if none at all from 12pis to 14psi but there will be lots more heat. even 12psi is risky for the exhaust wheel.
with stock ecu id say 160rwkw ish ? without piggyback or aftermarket ecu then yeah about there. 12psi and 14psi will do stock boost cut and your power will go out the window if you still have the stock ecu, it detects too much airflow and cuts the timing
A larger rolling diameter tyre will give a smaller power reading.....fact and proven.
when people upgrade wheel sizes, they generaly also reduce the profile so that the rolling diameter is still the same - wouldn't think a tyre company would recommend incresing the overall diameter
but even if the overall diameter is the same, then the 19s are probably going to weight a bit more than the stock 16s due to there needing to be more material to make up the larger rim. This would increase rotating mass and thus reduce power transmission through the wheels...
well ill get 3 runs anyway, ill do one on 10, one on 12 and another on 14 and see how i go from there.
how much power should i be expecting?
ive got a 3" turbo back, k&n pod, fmic.
well 2 weeks ago I dyno'ed my car..
I got 158rwkw. Was quite surpised.
This is stock r33, stock everything. POD and HKS cat back.
On the day stantaic had his auto GTT, that only did 156.0, also a R33 S2 (links's car) did 156.5. Both of them had cat backs and had stock air filter.
As has been said a number of times - dynos are a tuning tool.
I don't understand why you're asking what 'needs' to be done prior to a dyno run... as long as the car is running fine, put in fuel... put on dyno.
I have to ask - why run a higher boost than you run on the street? It won't give you a representative figure of what the car is running in street trim.
If you want a dyno sheet to say that the car makes 4000gigawatts, then just photochop it. Dynos are useful if you use the same dyno, prior to mods, then post mods, on a similar temperature / pressure day, to determine a relative increase of your mods.
its not that i want it to show more kw than it is on the street, im just asking questions on what to expect, and you guys have answered all of my queries.. are there any other things to look at besides fuel filter, spark plugs etc?
i just want a clean run.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
