im about to put my car on the dyno. right now my spark plugs are gapped at .8, but i fixed my coils (sanded the inside of them) over 2 months ago and havent gotten one single misfire since. i want to know if i can re-gap them to 1.1 to allow for a bigger spark. i'll be running 14psi on the day.
also, what are some things i can look at before putting it on the dyno?
https://www.sau.com.au/forums/topic/86302-tips-for-dyno-runs/
do you run 14psi on the street? if your on the stock turbo its the sure fire way of killing it, the heat generated by it will kill the exhaust wheel and i doubt it will make any more power if none at all from 12pis to 14psi but there will be lots more heat. even 12psi is risky for the exhaust wheel.
with stock ecu id say 160rwkw ish ? without piggyback or aftermarket ecu then yeah about there. 12psi and 14psi will do stock boost cut and your power will go out the window if you still have the stock ecu, it detects too much airflow and cuts the timing
A larger rolling diameter tyre will give a smaller power reading.....fact and proven.
when people upgrade wheel sizes, they generaly also reduce the profile so that the rolling diameter is still the same - wouldn't think a tyre company would recommend incresing the overall diameter
but even if the overall diameter is the same, then the 19s are probably going to weight a bit more than the stock 16s due to there needing to be more material to make up the larger rim. This would increase rotating mass and thus reduce power transmission through the wheels...
well ill get 3 runs anyway, ill do one on 10, one on 12 and another on 14 and see how i go from there.
how much power should i be expecting?
ive got a 3" turbo back, k&n pod, fmic.
well 2 weeks ago I dyno'ed my car..
I got 158rwkw. Was quite surpised.
This is stock r33, stock everything. POD and HKS cat back.
On the day stantaic had his auto GTT, that only did 156.0, also a R33 S2 (links's car) did 156.5. Both of them had cat backs and had stock air filter.
As has been said a number of times - dynos are a tuning tool.
I don't understand why you're asking what 'needs' to be done prior to a dyno run... as long as the car is running fine, put in fuel... put on dyno.
I have to ask - why run a higher boost than you run on the street? It won't give you a representative figure of what the car is running in street trim.
If you want a dyno sheet to say that the car makes 4000gigawatts, then just photochop it. Dynos are useful if you use the same dyno, prior to mods, then post mods, on a similar temperature / pressure day, to determine a relative increase of your mods.
its not that i want it to show more kw than it is on the street, im just asking questions on what to expect, and you guys have answered all of my queries.. are there any other things to look at besides fuel filter, spark plugs etc?
i just want a clean run.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
