Price Drop
Hey Guys,
I've rebuilt an RB26 for my R33 GTST so i have an almost complete RB25 for sale... I'm willing to sell the engine complete or separate for parts...
Performance Parts:
Subzero Plenum - This is a custom made plenum from Subzero in QLD... It uses the runners from the standard plenum with bellmouths at the top of each runner... This plenum is a tried and proven item which ran in Try9s 9second car... The other thing i noticed was that the throttle response improved dramatically (many people thought so too)... The plenum comes with standard GTR injectors, a dual feed custom fuel rail and Ford throttle body (80mm or 90mm) with antilag kicker solenoid and throttle cable... - $1100
3in Dump and Front Pipe for standard turbo - $200
Apexi AVC-R boost solenoid (old school) - $200
Stock Parts:
Standard Turbo with or without manifold - $300
VCT Head with powder coated rocker covers (no coils) - $300
Standard bottom end, fine except ring lands broken - $400
If your interested in anything, let me know and i'll see what i can do for you...
Reason for Selling:Rebuilt RB26
Payment Conditions:Buyer pays for postage
Contact Details:PM & Mobile: 0413 656 842
Edited by MetBlue_GTST
y use that plenum when you had a stock turbo?
Because i didn't want to have an extra metre and a half of piping, also the plan back then was to put a Garrett GT30 on, but that didn't happen then... The biggest thing i noticed, was the throttle response difference i got between the standard plenum and the new one... Was a massive improvement...
what computer were you running ?
I'm keen on plenum and injectors just not sure how the injectors will work.
what needs to be done to use this plenum and injectors on r33 gts-t
thanx
thanx
I'm running an Autronic SM2...
The plenum will bolt straight onto the head no problems... As for the injectors, from memory they will not work on the standard GTST computer, but i think a resistor pack is required to change the impedance... If you do a quick search for standard GTR injectors and see what people have done with them, you'll quickly find the answer... :D
  • 1 month later...
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
