Price Drop
Hey Guys,
I've rebuilt an RB26 for my R33 GTST so i have an almost complete RB25 for sale... I'm willing to sell the engine complete or separate for parts...
Performance Parts:
Subzero Plenum - This is a custom made plenum from Subzero in QLD... It uses the runners from the standard plenum with bellmouths at the top of each runner... This plenum is a tried and proven item which ran in Try9s 9second car... The other thing i noticed was that the throttle response improved dramatically (many people thought so too)... The plenum comes with standard GTR injectors, a dual feed custom fuel rail and Ford throttle body (80mm or 90mm) with antilag kicker solenoid and throttle cable... - $1100
3in Dump and Front Pipe for standard turbo - $200
Apexi AVC-R boost solenoid (old school) - $200
Stock Parts:
Standard Turbo with or without manifold - $300
VCT Head with powder coated rocker covers (no coils) - $300
Standard bottom end, fine except ring lands broken - $400
If your interested in anything, let me know and i'll see what i can do for you...
Reason for Selling:Rebuilt RB26
Payment Conditions:Buyer pays for postage
Contact Details:PM & Mobile: 0413 656 842
Edited by MetBlue_GTST
y use that plenum when you had a stock turbo?
Because i didn't want to have an extra metre and a half of piping, also the plan back then was to put a Garrett GT30 on, but that didn't happen then... The biggest thing i noticed, was the throttle response difference i got between the standard plenum and the new one... Was a massive improvement...
what computer were you running ?
I'm keen on plenum and injectors just not sure how the injectors will work.
what needs to be done to use this plenum and injectors on r33 gts-t
thanx
thanx
I'm running an Autronic SM2...
The plenum will bolt straight onto the head no problems... As for the injectors, from memory they will not work on the standard GTST computer, but i think a resistor pack is required to change the impedance... If you do a quick search for standard GTR injectors and see what people have done with them, you'll quickly find the answer... :D
  • 1 month later...
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
