There is a difference.
I have pulled the rom files of both a silvier Rb20 auto and a manual.
The main tables(fuel/ignition) are pretty much the same. The rev limit seems higher on the manual though(although this could be a fluke). The actual map files are not the same though.
From what I understand the auto softens the timing in the higher RPM so when you stand on it, during the gear change there is not as much tourqe.
Hence going from an auto to manual, a auto ecu would work ok, you just may find the top of your rpm lacking slightly. If you were to go the other way, manual ecu in an auto, you will find your gearchanges some what un-pleasant with the auto box at full throttle.
https://www.sau.com.au/forums/topic/86313-computers/#findComment-1563452
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
