I WANT TO SELL ALL PARTS TOGETHER. DUE TO STUFF AROUNDS, FALSE PROMISES AND DEALS FALLING THROUGH THIS WHOLE PACKAGE $1200
I GUARENTEE YOU THIS WILL BE THE BEST OFFER U WILL FIND
1ST TO COME UP WITH THE CASH GETS IT ALL
ALL PARTS ARE R32 GTR ORIGINAL
r32 DIFF AND AXCLES MOUNTED IN SUSPENSION BRACETS
R32 COMPLETE REAR SUSPENSION FROM VSPEC (POWER STEERING RACK, HYDROLIC SETUP, HALF TAILSHAFT BRACS ETC PLUS HEAPS MORE)
R32 BRAKE BOOSTER
R32 CLUTCH BOOSTER
R32 DOOR TRIMS (ALL 4)
R32 FRONT CRASH SUPPORT
R32 WINDSCREEN WHIPER MOTORS AND ARMS (2)
R32 STEERING SHAFT
R32 AIRCONDITIONING AND HEATER BOX (COMPLETE UNDER DASH UNIT)
R32 SHOCKS AND SPRINGS
R32 THERMO FAN
R32 AIR CON COMPRESSOR
R32 STARTER MOTOR
R32 HANDBRAKE AND CABLE
R32 CLUTCH PEDAL
R32 TAILIGHTS
R32 ABS UNIT (HARD TO FIND)
R32 CENTER GAUGES
R32 CENTRE CONSOLE
R32 WIRING
R32 FUEL TANK FILLER HOSE
THESE PARTS ARE LOCATED IN SYDNEY AND U MOST PROBERLY WILL HAVE TO PIC THEM UP (OR DELIVERY WILL BE $50)
RING ME ON 0414 088 087
https://www.sau.com.au/forums/topic/8638-best-deal-r32-gtr-parts-package-fs/
Originally posted by Boxhead
4 door trims? theres only 2 doors mate
Boxhead,,,if your not interested in buying,,,DON'T POST,,,,.
I think he means the inner rear 1/4 trims,,,.
Neil.
ok then let me clarify myself. i basically could not be bothered giving a description on every part but here it is
2 * front door trims (some marks)
2* rear trim that fits on the body next to the rear seats. ie the plastic mould with vinal covering and grey swade material incerts in them. (some marks)
anything else needing clarifying ???. i keen buyer would ring me up and ask for clarification
thanks ndr
Tracka PM or email me ur banking details and how much u paid for postage so i can xfer the money first thing tomorow.
cheers mate.
On ya Tracka,
PM me your contact details and I'll "Payanyone" when we are going to pick em up...
If you are too far from my mate, I'll get em couriered... as I have a front bar leaving blacktown as soon as we get the trims.
My time frame is getting them here by.... actually i have a cage coming from Bonds also... I ranting now!
Send Me details and We'll go from there
Regards :D
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
