That sucks Tommy. It's your tyres though. I personally love the rain and was having a great time yesterday with the wet roads. My front torque split guage peaked at 42.1% - that's the highest I've ever seen it go! I must've been spinning all four for it to resort to that.
I've got 16" protenza's III on stock rims.. they're good 90% of the time in the wet... however give them any stick in 2nd you'll be having fun up the road.. also going around an off camber roundabout in 2nd.. they decided to let go.. combine with a LSD and they both started spinning.. alright though.. just back off and it's snaps back..
personally I need some wider tyres.. but I think the protenza's are alright..
I just don't understand people who skimp on tyres :)
They're the ONLY thing sticking your ass to the asphalt and saving your ass... I'd even say that it's the most important thing on your car.... and yet there are still people riding around on Falken Ziex tyres :) I think the solid plastic tyres on my model cars give more grip than those useless things :(
And if you think that "oh but it won't be as much fun because I won't be able to get the ass out with sticky tyres, that's absolute craaaaaaap. Of course you can still induce power oversteer. But in any case, once you realise just how much HARDER you can launch, and how much FASTER you can corner with sticky tyres, you'll soon forget about stupid sideways driving ;)
This is true.
I admit i don't have great tyres but i drive like a granny in the wet. I would rather drift in the dry(if i had the power).
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
