Item Condition: All in good or excellent condition
Price and Payment Conditions: Prefer cash, direct deposit & COD can be arranged at buyers expense.
Contact Details: PM me..
Hey All
Cleaning out the garage and have the items below for sale..
R33 Gts-t
Bride Seat ($650)
NGK IridiumIX Spark Plugs (x6) 2 Suit R33Gts-T (Brand New) ($120)
Cracked R33 Front bar (White) ($150)
TEIN HR Full Suspension Set (Front n Rear) ($800)
Audio
Fusion FPC-525 PowerPlant 180watts Brand New Speakers In Box ($120)
Soundstream Mules 12inch x 2 in carperted box (250RMS) ($800)
Assorted Items
01-02 Orginal Lancer Tail Lights ($200)
s15 standard front bar (Black) ($350)
Nissan Pulsar gti-r airfilter/box ($80)
PM me for any further details, hopefully these pictures will help with sale...
Kind Regards,
Chris
Edited by chris2five
https://www.sau.com.au/forums/topic/86419-fs-skyline-car-bitz/
hey mate
What condition is the tein suspension in? any leaks? Obviously height adjustable, are they dampner adustable? Does it come with the adjustment tool?
Cheers buddy
The tein suspension are in good condition. There seams to be no leaks as far as I can see, and I dont have the adjustment tool.
Thanks.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
