Hi guys
i've done a search on this but couldn't really find the answer to this.
for an R33 gts-t, if i disable hicas by just pulling the fuse out of the fuse box without fitting a lock bar, would the rear wheels have some freeplay?
logically i thought it shouldn't have any freeplay or otherwise nissan wouldn't even put it on (there'll be freeplay before hicas activates at speed <80km/h), but i guess i may be wrong or otherwise there's no point for people to make/buy lockbars
thanks
Edited by tkch55
https://www.sau.com.au/forums/topic/86421-hicas/
No doubt, sydneykid will post a reply to this, but since I'm here I might as add my 2c.
The system is failsafe so your rear wheels are not going to flail around. I've taken the fuse out for a run at a track day with no serious effects. Although on my way home (fuse out) all od a sudden I needed 15degrees of steering to get the car to go straight which went away 100m down the road, so there must be some movement allowed there.
I'm going with one of GTRgeoff's lock bars, if you really want to remove the HICAS just spend the $150. Can't wait to get it Geoff!.
https://www.sau.com.au/forums/topic/86421-hicas/#findComment-1562902
Hi guys
thanks
JCML covered it pretty well, he has read some of the 100 or so posts on dissabling HICAS, that you would have found if you had done a search.
"Freeplay" implies thsat there is some slop in the system, when it's new there isn't. But that isn't the issue, as you would have found out if you had down a search.
The problem is movement, the rear rack can move under load without the HICAS connected, as you would have read in some other peoples posts if you had done a search.
The best solution by far is to totaly remove the HICAS, there is a "How to" guide on it As you would have ........well....you get the idea
:) cheers :)
PS; did I mention that you should do a search?
https://www.sau.com.au/forums/topic/86421-hicas/#findComment-1563054
i have done a search and went through some threads, maybe i didn't go through this thorough enough, so my apologies for wasting the internet resources
however, what i was really after is if there's any potential danger if the fuse is taken out
here's the reason
my mate who i bought the car from had a stalling problem, so he took it to a workshop and their solution to the stalling problem was to pull the hicas fuse out.
they said the hicas in this car is fauty, and it is turning the wheel regardless of the speed of the car, giving the engine extra load and making it stall, so for safety reason as well as to prevent the engine from stalling they took the fuse out. (it did help to prevent the engine from stalling to a certain degree though)
i don't know whether this is true or not, and i'm a bit skeptical about it.
however, the vague feeling from the rear is still there whether i have the fuse in or not even at speed< 80k, even at a straight run
hence here i am trying to weight out whether or not i should put the fuse back in before the lockbar goes on.
thanks for your input guys, much appreciated
https://www.sau.com.au/forums/topic/86421-hicas/#findComment-1563286
here's the reason
I am sorry I don't understand the question. Is it;
1. Will dissabling the HICAS fix a stalling problem? No, find out what the real problem is and fix that. The ECU has power steering load compensation, so increased power steering load from the HICAS should make no difference to the idle.
2. Is there any danger if the fuse is taken out? Yes, you have no hydraulic pressure holding the rear steering rack stable. Given enough load the rack will move. It might do it slowly and you will find yoursewlf driving down a straight road with the steering wheel turrned. Or it might do it suddenly and you will find what the scenery looks like in close up.
Both #1 and #2 are band aids, find out what the real problem is and fix it. In the case of HICAS, the best fix is to remove it.
:) cheers :(
Edited by Sydneykid
https://www.sau.com.au/forums/topic/86421-hicas/#findComment-1563480
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
