THIS IS WHAT IT SAYS ABOUT IT:
just want 2 know if any 1 has had anything 2 do with them..??
NISMO RACING CHARGING STABILIZER
NEW Racing Charging System
Fits all vehicle (Nismo special design for Nissan vehicles)
Benefits:
** Increase Torque ** Increase Fuel Economy ** Car Response Up
** Stable Idling ** Quick Engine Start ** Lesser Engine Noise
** Optimize Electrical Equipment performance
EBay again?
It's not genuine Nismo btw.
You're much better off spending (less than) that on some thick gauge wire upgrading your car's earthing points. See this thead for an example: http://www.skylinesaustralia.com/forums/in...topic=82677&hl=
That sounds like the HKS Circle Earth system. Autosalon did a review of the HKS one a while back and said for the money it wasn't worth it, and you'd be better off making one up yourself like raz0r$harP suggested. But it makes your engine bay look nice!
"Oh no it's the cops!"
"Worse, the police cops!"
Yah it is expensive !!!
But hey they are samples so I will try them out.
I have to admit that when I first put it on my car, it was idling much nicer. When I had the Metal Plus it did seem to get me more kms, then I tried the Torque one and kms per tank went down but my car does feel more torquey.
There are 3 other people trying various ones so we will see if we can come to a conclusion at the end.
Edited by beefy
Autosalon tested the HKS Circle Earth kit on 3 cars: a '94 Pulsar GTi, a series V RX7 and a Forrester XT. From memory they didn't notice any difference in the RX7, but in the Pulsar the owner said he thought it started easier on cold mornings, and his audio system sounded slightly better. In the Forrester, they did notice a gain of like 2kw's or so, but a slight drop in torque in the mid range. They also gave a step by step guide of how to make one yourself and what to buy, was very easy to make for fiddy bucks. They sound like a good idea in theory though, but I'd rather try to make my own for $50 than spend like $380 or so for a brand name one.
well these 1's might be cheapees but for $70 they sound like they are worth a go 2 me..?? anyway i am after sound quality.. so it should help out there
The brand name ones are of questionable use: they probably make some difference of cars with poor earthing. The Pivot ones cost about $120.
Do you really think some Ebay knockoff with a fake brand name is going to be worth the hassle?
Ive had the Apexi one installed to help with Grounding and Idle issues in my car, they definitely help with the idle at the very least. Im not sure about all the other claims of more torque and better fuel economy. Seems like every mod in eBay says it improves fuel economy.
Is there specific point in the engine bay these wires are meant to go to?
Or is it just pick a metal spot on the engine and it'll be allright?
Ive been watching this topic for a while...
the actual power stabilisers have nothing to do with earthing, so in fact you are only comparing the quality of cables. Good quality cable from an electronics supplier will give you very similar earthing results. Another thing is that if the car already has a good earth, the kit will not provide a huge difference, but for older cars with poor earths it will be beneficial.
the powerstabiliser box smooths out votage fluctuations, which can help with starting and ICE. you may not even see an increase in votage tho.
in my opinion the PIVOT one is not worth it, they are relying on people to buy for the brand, I have done alot of research into these and have used similar systems on RC cars in the past.
I have built my own power stabiliser, for around $25 you can make a quite decent one that is compareable or the same as alot of commercial ones, the pivot one may be the best but imho it is not $75 better. I was planning on selling these but I did not want to supply a product that produced such a small performance gain, and testing on my car did not convincingly prove that it provided a noticable result
Edited by midnight
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
