YAY New Cooler Is In
  • Replies 92
Originally posted by INASNT
and how did i know u would say that, how predicitable u r ambz!
anyway, stop hijacking my thread, u bloody tamil tiger!!!
haha...like a tiger...*roooaaaar* :lol:
geezes....$600 for piping...that's more than my intercooler alone :eek: (33 GTR FMIC)
I was just thinking mild with hi-temp paint on it for myself :)
the piping came in 3 pieces so it saves time on welding and adjust etc!
If u were to buy 2.5inch pipe get it coated and then mess around with labour of getting the right angles etc it comes close if not more than 600!
pipe from turbo to intercooler intake, pipe from intercooler exit to engine bay, and pipe from that to intake!
then dont forget about all the hose clamps, silicon hoses and rubber fittings!!!
u sure franks is just gonna let u pull off that off just so u can get a copy of it??
I know if some1 asked me to pull my front bar and all clamps, hoses and piping off just to copy my piping, i would b asking what was it in for me!! :)
yup b'cos he has another car to drive for awhile and I'm making a box for my apexi cone filter, so he'll just grab a copy of that off me. :P
hmm what does the box u r making look like now! I had a partition in place when i had the stock cooler and piping and now it is usless since i have heapes more room to play with now!
I need to get a nice funnel up where the stock cooler was with sum piping into the engine bay through the stock cooler holes!!
I haven't made it yet, gonna make some templates from cardboard, then trace it onto the aluminium sheets I got at home, bring to a laser cutting place and get 'em cut out, then welded together and powercoated flat black so it (hopefully) will look stockish and the cone filter will be hidden.
EDIT: this is for a 34...would it be same fit as a 33?
Originally posted by ed
ahhh, looks like the hardwork has already been done?!?!?!
will have a closer look tonight.
i think you will find on the 34 that the radiator overflow is in the way - as it is on the same side as the airbox [LH P/S]. Whereas on the 33 the airbox is near the battery [RH D/S]
that template is if u have the stock cooler and piping, so u gotta modify it abit with fmic. in r33 the battery is in the boot so it aint in the way of the airbox! :)
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
