Hi All
I just purchased a gt 30bb turbo off a friend Unfortunately he was pretty useless in giving me specs of the turbo!!!
I want to put the thing on an rb20 and was wondering what kind of lag I would get from the turbo?
Also does any one know the exact specs of the turbo?? such as a/r ratios and compressor and turbine sizes, and what hp there rated at. Done the search came up with nothing.
The part number is Part # 705329-0002
Any help would be great
Cheers
anthony
Edited by black sky
https://www.sau.com.au/forums/topic/86508-gt30bb/
Can't really answer your questions on specs, however I can tell you that any GT30BB turbo will be laggy on an RB20.
there is a thread somewhere on how these turbo's are on the rb25 which is larger in capacity and compression..
DISCOPOTATO03 on these forums will be able to tell you what the specs are with that number
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1563668
Hey black sky I have a GT30 on my RB20 reason being i got it for free so why not put it on. I like it the lag doesn't bother me that must in one way it is good because it is safer in the wet cause it doesn't want to boost every time you take off. My car hits full boost at about 4000rpm to 7200rpm it is quiet a big rush to i might add. it is also good because for just normal driving i can just cruise around with out it want to step out under boost all the time if you have your foot down, if you want to get into it i just boost up first and once you are out of first gear and change it will boost all the way through you gears if you keep your foot into it. It is all good and well to say get something smaller put if you got this at the right price why not put it on just mean you will start boost at 4000 instead of 3200 - 3500 with a smaller turbo. sorry i cant help you with the spec's as the guy that gave me mine didn't say much about it just that it was only 2000km old he did say that it was good for at least 500bhp. So put it on and good luck with it
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1565917
wheels 24 - lets say you're driving along in the wet and come to a street that you need to turn left in to and it is a steep hill.
a rwd rb20 powered car with no boost in the wet..
how you going to get up that hill at anything above datsun 120y speeds?
what do the rb20's have?
8.5:1 compression?
with no boost, in 2nd gear (I'd assume) how can you possibly have te car moving?
it would feel crap to drive around like that.
full bost at 4000rpm... what exactly is full boost?
what psi or some other form of pressure measurement is your car tuned for?
and around 2500-3000rpm, do you see any sort of positive pressure?
or do you always have to shift back to first gear for situations like I've described above?
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1565931
Thanks guys
yea i got the turbo pretty cheap so i thought why not wack it in. at the moment i've got a t3/t4E in there and it's makin full boost at about 4600 so 4000 would be like a dream come true. I've got this in a 180sx so the car's light as all F#$k and she goes good with the T3/T4 turbo in it but i just wanna make some easy power without pushin to much psi through the engine hence the big turbo.
at the moment i'm gettin 204kw@ the wheels in 4th gear and but my coil packs are fowling and the turbo's isnt flowing air properly by the way that's bein made on 15psi.
well if any one else has any more oppinions post up. Thanks for your first hand knowledge wheels_24
Cheers
anthony
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1566150
well i do see some increase in power just after 2500 it isn't that bad that i have to drop down to first it still has pretty good pick up when i mean by full boost when i hit about 4000 that is really were it wants to take off and throws you back in your seat i was running 16psi but it seems that i didn't have a very good engine since that i have just had the engine pulled down for a rebuild. But i have taken my car up around olinda and the hills past ferntree gully and it was fine to drive not a problem. Even though the RB20 is a smaller engine they still have a little bit of pick up my mods a as follows:
bosch 040
GT30BB
bigger injectors
fuel reg
wolf 3D
3" turbo back
FMIC
POD
45mm waste gate
Once i have done my rebuild i have been told should be able to get up to 240rwkw maybe with a good tune well thats what chasers think as i should be able to run a little more boost after it is run in as it is a fresh engine and i am putting aries forgies in
Edited by wheels_24
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1568226
So your making less than 240rwkw now on 16psi out of a GT30 ?
Geebus.
You could make more power with better response from a GT28 of equalently sized turbo.
with a typical GT30 you should be aiming for 280rwkw at a minimum.
As for the GT30, what spec is it? thats gonna make a lot of difference
When you say 16psi @ 4000rpm, is that under full load from 2000rpm in 4th on a dyno?
Or realistic stuff on the street?
I'll be betting 1st/2nd your well above 5000rpm before making any moderate boost
Actually, further more... do you have a dyno graph to post up?
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1581377
thats when i am driving around on street every day driving i think the reason why i wasn't heaps of power was because of my engine was not in good shape it apears as it is getting a complete rebuild, another reason was because i didn't have a after market fuel pump. I have now bought a bosch 040 pump and once i have got my car back and run the engine in i am hoping to see a good improvement hopfully i do have a graph but no scanner
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1582024
it would be different from 3rd to 4th etc.
In 2nd its making 16psi @ 4000rpm and the same in 4th.
There is no way it would be the same
Post the graphs etc is a good place to start to get a more accurate idea of whats going on...
Spec of the turbo also
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1582155
i don't have a scanner sorry so i cant post up the graph, and for the spec's i don't know them either sorry because the guy that gave it to me didn't tell me what they were and it didn't really bother me that much cause he showed me the receipt him buying it 2 months before giving it to me. you are right there is a difference between 2nd and 4th and the fact that i don't really come on boost in 4th as i only drive this on the road so unless i take it out to say 140 - 150 in 4th it want really hit boost so i cant really say what boost it gets to in 4th. when i get my engine rebuilt and run it up again i will see if i can get my little sister to put it on for me a school for you
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1582469
is you GT30 on a RB20 or RB25
ive got a gt30r on a rb20 with a .63ar turbine.
engine also has 'low' compression (140 across the board).
right now it runs tooo freeking lean under spool so it takes forever to spool up but once it does it hits like a sledge hammer and you are off.
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1584622
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
