Hi All
I just purchased a gt 30bb turbo off a friend Unfortunately he was pretty useless in giving me specs of the turbo!!!
I want to put the thing on an rb20 and was wondering what kind of lag I would get from the turbo?
Also does any one know the exact specs of the turbo?? such as a/r ratios and compressor and turbine sizes, and what hp there rated at. Done the search came up with nothing.
The part number is Part # 705329-0002
Any help would be great
Cheers
anthony
Edited by black sky
https://www.sau.com.au/forums/topic/86508-gt30bb/
Can't really answer your questions on specs, however I can tell you that any GT30BB turbo will be laggy on an RB20.
there is a thread somewhere on how these turbo's are on the rb25 which is larger in capacity and compression..
DISCOPOTATO03 on these forums will be able to tell you what the specs are with that number
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1563668
Hey black sky I have a GT30 on my RB20 reason being i got it for free so why not put it on. I like it the lag doesn't bother me that must in one way it is good because it is safer in the wet cause it doesn't want to boost every time you take off. My car hits full boost at about 4000rpm to 7200rpm it is quiet a big rush to i might add. it is also good because for just normal driving i can just cruise around with out it want to step out under boost all the time if you have your foot down, if you want to get into it i just boost up first and once you are out of first gear and change it will boost all the way through you gears if you keep your foot into it. It is all good and well to say get something smaller put if you got this at the right price why not put it on just mean you will start boost at 4000 instead of 3200 - 3500 with a smaller turbo. sorry i cant help you with the spec's as the guy that gave me mine didn't say much about it just that it was only 2000km old he did say that it was good for at least 500bhp. So put it on and good luck with it
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1565917
wheels 24 - lets say you're driving along in the wet and come to a street that you need to turn left in to and it is a steep hill.
a rwd rb20 powered car with no boost in the wet..
how you going to get up that hill at anything above datsun 120y speeds?
what do the rb20's have?
8.5:1 compression?
with no boost, in 2nd gear (I'd assume) how can you possibly have te car moving?
it would feel crap to drive around like that.
full bost at 4000rpm... what exactly is full boost?
what psi or some other form of pressure measurement is your car tuned for?
and around 2500-3000rpm, do you see any sort of positive pressure?
or do you always have to shift back to first gear for situations like I've described above?
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1565931
Thanks guys
yea i got the turbo pretty cheap so i thought why not wack it in. at the moment i've got a t3/t4E in there and it's makin full boost at about 4600 so 4000 would be like a dream come true. I've got this in a 180sx so the car's light as all F#$k and she goes good with the T3/T4 turbo in it but i just wanna make some easy power without pushin to much psi through the engine hence the big turbo.
at the moment i'm gettin 204kw@ the wheels in 4th gear and but my coil packs are fowling and the turbo's isnt flowing air properly by the way that's bein made on 15psi.
well if any one else has any more oppinions post up. Thanks for your first hand knowledge wheels_24
Cheers
anthony
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1566150
well i do see some increase in power just after 2500 it isn't that bad that i have to drop down to first it still has pretty good pick up when i mean by full boost when i hit about 4000 that is really were it wants to take off and throws you back in your seat i was running 16psi but it seems that i didn't have a very good engine since that i have just had the engine pulled down for a rebuild. But i have taken my car up around olinda and the hills past ferntree gully and it was fine to drive not a problem. Even though the RB20 is a smaller engine they still have a little bit of pick up my mods a as follows:
bosch 040
GT30BB
bigger injectors
fuel reg
wolf 3D
3" turbo back
FMIC
POD
45mm waste gate
Once i have done my rebuild i have been told should be able to get up to 240rwkw maybe with a good tune well thats what chasers think as i should be able to run a little more boost after it is run in as it is a fresh engine and i am putting aries forgies in
Edited by wheels_24
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1568226
So your making less than 240rwkw now on 16psi out of a GT30 ?
Geebus.
You could make more power with better response from a GT28 of equalently sized turbo.
with a typical GT30 you should be aiming for 280rwkw at a minimum.
As for the GT30, what spec is it? thats gonna make a lot of difference
When you say 16psi @ 4000rpm, is that under full load from 2000rpm in 4th on a dyno?
Or realistic stuff on the street?
I'll be betting 1st/2nd your well above 5000rpm before making any moderate boost
Actually, further more... do you have a dyno graph to post up?
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1581377
thats when i am driving around on street every day driving i think the reason why i wasn't heaps of power was because of my engine was not in good shape it apears as it is getting a complete rebuild, another reason was because i didn't have a after market fuel pump. I have now bought a bosch 040 pump and once i have got my car back and run the engine in i am hoping to see a good improvement hopfully i do have a graph but no scanner
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1582024
it would be different from 3rd to 4th etc.
In 2nd its making 16psi @ 4000rpm and the same in 4th.
There is no way it would be the same
Post the graphs etc is a good place to start to get a more accurate idea of whats going on...
Spec of the turbo also
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1582155
i don't have a scanner sorry so i cant post up the graph, and for the spec's i don't know them either sorry because the guy that gave it to me didn't tell me what they were and it didn't really bother me that much cause he showed me the receipt him buying it 2 months before giving it to me. you are right there is a difference between 2nd and 4th and the fact that i don't really come on boost in 4th as i only drive this on the road so unless i take it out to say 140 - 150 in 4th it want really hit boost so i cant really say what boost it gets to in 4th. when i get my engine rebuilt and run it up again i will see if i can get my little sister to put it on for me a school for you
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1582469
is you GT30 on a RB20 or RB25
ive got a gt30r on a rb20 with a .63ar turbine.
engine also has 'low' compression (140 across the board).
right now it runs tooo freeking lean under spool so it takes forever to spool up but once it does it hits like a sledge hammer and you are off.
https://www.sau.com.au/forums/topic/86508-gt30bb/#findComment-1584622
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
