i am about to up grade my car again and i got my turbo gt35r got 500hp fule pump got front mount got a hd clutch and im going to put in some 555cc injectors this means i will be able to boost it up but iam worried if i going to get it over 400hp which im pretty sure i will i am going have to up grade a lot more at the moment i have 370hp does any one know what other things i will have to do to my car
Edited by wallystyles
https://www.sau.com.au/forums/topic/86585-400hp-what-upgrades/
clutch
airflow meter
555cs probably wont be enough, 740c's are only like $20 extra each
youll want a nice big exhaust for a gt35. 4" or 3.5" from turbo back
youll want some suspension work and brake work done otherwise it will be a coffin. aftermarket ecu a must. unsure how std fail rail will go.
the only you dont have is lag, but that will come when you put that sucker on :D
you'll need a properly built motor if you expect it to last any moderate length of time.
The GT35 is overkill for what you want to begin with.
Its a turbo that will pump 350rwkw on pulp given the right spec.
When you say you have 370hp now, is that RWHP?
Although i doubt it as you make no mention of having injectors in there as yet
Bigger isnt always better, and for 400hp (which i assume isnt 400rwhp as i said above with the 370hp)
A car will a smaller turbo will eat you for breakkie ;)
i do have 370 rwhp i also have a apexi power fc and my turbo is allready on but i still have stock injectors will 740cc injectors be able to push my turbo harder i want somthing that will last as well as go hard but i dont want to kill myself the car is fast now i was going to put the injectores on next week and a custom radator on it how much will a clutch cost and what sort will be good for my set up
well isn't 400rwhp still under 300 RWKW??
550cc injectors will do that fine without having an adjustable FPR. 740cc would just make idle quality really bad.
edit -- is that your widebody gtst??? looks good i lke the gurads etc.
Edited by Craved
My injectors hit max with 325rwhp through a Malpassi fuel pressure reg.
There is a general consensus that 250rwkw it about the max power you can get from the stock injectors.
I'd question your injectors (maybe they are aftermarket and you don't know it, maybe they have been high flowed) or I'd question the accuracy of the dyno.
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
