Problem With Rim
DJR34
 Share
Hey guys,
I got a prob with my front passenger rim on my 33. i thought the tyre somewhere had a leak as the tyre leaks air over about a month b4 i need to constantly reinflate it, so im always topping it up. i got it all checked out thinking it was the rubber, but they found a hairline crack in the actual rim.
I have 18" ROH Drift R's on the car, and i dont really want to replace that 1 rim which will prob cost 500 bucks, but it looks like i have no choice, it must be fixed or it will always continue to leak.
Is it possible to like get a tube put in just that wheel to fix it, as these type of wheels are tubeless..if thats the case id much rather pay 40 bucks than 500.
any advice would be appreciated
you can get it tubed at your local tyre place should be no dramas however i would be concerned of the safety of the rim itself if its cracked.
it could be unsafe and expand more or crack more at high speeds, that would be fatal, especially on the front
um iam pretty shore they dont make tubes for 16-17-18s coz they low profile, could be wrong about 16s but others iam shore off, just get some reall good glue n tank the tyre look 4 where air is comeing out n GLUE it, but i would fix or get new 1 if u wont i can get u these rim most likly.
i would advise against the tube idea even if you can find one for your wheel as they are not the safest things going around (excuse the punt)
as someone suggested best thing is to get it repaired by wheel repairers.
I got the wheel checked out at an ally repairer, the wheel is f***ed. the crack is too close to where the spoke meets the inner part of the rim so the only option is a new rim. but the rim is $280 so its not too bad..i was expecting them to be around 400-500 per rim.
And yes im still getting the 34. had it checked out and all looks good.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
