i was sitting at the lights today when my car suddenly droped from idle-800rpm to a near stall only to correct itself instantly. i took off and drove about 100metres when it suddenly did the same thing,but this time whilst driving. since then it has done it several times. it doesnt sound like it is dropping a cylinder,and only looses power or nearly stalls for a second before returning to normal. the car is an r33 s1.5 det. any ideas?? :D
https://www.sau.com.au/forums/topic/86605-stalling-car/
could be coils or plugs..sounds like something electrical....afm also...or een crank angle sensor....try the chea stuff first or take it to a workshop if your lazy....or if u do stuff your self find someone with same car and swap coils over and see if it still does....if still does it tr afm....and the crank angle sensor u will probably need a shop to do anyway...
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1565329
i just changed the plugs a month ago to ngk bkr5eix-11 re-gaped to 0.8. I have changed the fuel filter about three months ago, and fuel hose. the bov is a GFB atmospheric vented valve, but ive got a HKS EIDS, to control the rich spike. ive noticed since i have changed the plugs it misses the slightest bit when idling.
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1566000
mine was running like shit and nearly stalling cuz of an o2 sensor. It could be heaps of shit. Anyone or any performance mech will just keep swapping or fixing shit till they figure it out. Just take it to an EFI diagnostic workshop and they will figure it out quicker and cheaper. Then take it to your performance mech to be fixed or do it yourself. That's what i did
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1567368
busted o2 wont make it stall, try stock bov. the bov is venting air the computer is expecting to have 100 units of air but your bov vents the majority of that air to atmosphere so it only has 20 units of air in the system so it adds fuel to match 100 units of air and stalls cos the mixture is off the planet. atmo bov = stall
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1567499
My S14 had a similar problem.
Mine turned out to be the wiring to the AFM.
basically, the AFM plug, the cable that goes off it, when my car is idling fine, if I touched the wire or moved it in a certain direction, the car would stall.
I did the cheap option and found a position where it wouldn't stall and taped it to there.
it's not the bov or it would happen when you are COMMING to a stop after venting the bov.
and you have that HKS doobie anyway..
start your car, open bonnet, move the AFM around, move the cable from the AFM plug around..
see if any of that makes your car stall.
good luck
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1571583
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
