i was sitting at the lights today when my car suddenly droped from idle-800rpm to a near stall only to correct itself instantly. i took off and drove about 100metres when it suddenly did the same thing,but this time whilst driving. since then it has done it several times. it doesnt sound like it is dropping a cylinder,and only looses power or nearly stalls for a second before returning to normal. the car is an r33 s1.5 det. any ideas?? :D
https://www.sau.com.au/forums/topic/86605-stalling-car/
could be coils or plugs..sounds like something electrical....afm also...or een crank angle sensor....try the chea stuff first or take it to a workshop if your lazy....or if u do stuff your self find someone with same car and swap coils over and see if it still does....if still does it tr afm....and the crank angle sensor u will probably need a shop to do anyway...
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1565329
i just changed the plugs a month ago to ngk bkr5eix-11 re-gaped to 0.8. I have changed the fuel filter about three months ago, and fuel hose. the bov is a GFB atmospheric vented valve, but ive got a HKS EIDS, to control the rich spike. ive noticed since i have changed the plugs it misses the slightest bit when idling.
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1566000
mine was running like shit and nearly stalling cuz of an o2 sensor. It could be heaps of shit. Anyone or any performance mech will just keep swapping or fixing shit till they figure it out. Just take it to an EFI diagnostic workshop and they will figure it out quicker and cheaper. Then take it to your performance mech to be fixed or do it yourself. That's what i did
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1567368
busted o2 wont make it stall, try stock bov. the bov is venting air the computer is expecting to have 100 units of air but your bov vents the majority of that air to atmosphere so it only has 20 units of air in the system so it adds fuel to match 100 units of air and stalls cos the mixture is off the planet. atmo bov = stall
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1567499
My S14 had a similar problem.
Mine turned out to be the wiring to the AFM.
basically, the AFM plug, the cable that goes off it, when my car is idling fine, if I touched the wire or moved it in a certain direction, the car would stall.
I did the cheap option and found a position where it wouldn't stall and taped it to there.
it's not the bov or it would happen when you are COMMING to a stop after venting the bov.
and you have that HKS doobie anyway..
start your car, open bonnet, move the AFM around, move the cable from the AFM plug around..
see if any of that makes your car stall.
good luck
https://www.sau.com.au/forums/topic/86605-stalling-car/#findComment-1571583
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
