AVAILABLE NOW [EDIT]
Hey guys,
this set is on it's way from Japan.
Under 10,000k's of use.
HKS Hiper Damper
10 damper settings.
8kg front springs, 6kg rears.
$1600 delivered Australia wide.
Edited by JDMimports
  • 2 months later...
The HKS coilovers are landed and ready to find a new home.
We also have this landing at the same time as the Cusco's...
Apexi AX53B70P25 Turbo. Brand new. Rated at 400PS.
Expecting this to land end of Dec to early Jan.
$2090
We also have some Rays Nuts in stock.
$215 delivered to your door.
or as a cheaper alternative, we have a used blue set here for $70
Used Nismo Gmax II twin plate clutch kit (pull type) to suit BNR32 and BCNR33.
Pressure plate, flywheel and centre plate in good condition.
Clutch plates have a little bit of life left.
A bargain for $400
  • 5 months later...
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
