Bride Style Reclining Racing Seats - $449 Per Pair - In Stock!
  • Replies 175
Posted Images
Will you be getting in any of these seats that are fully blue along with the shipment of seats that are fully red? Will be interested as soon as I can get some dimensions for the seats.
Hi mate, thanks for your enquiry. Unfortunately we dont have any all blue versions of the Bride style seats coming, only black with the blue centre (which are in stock now)
Dimensions below as posted on page 2
Hi guys, approximate dimensions of the seats are as follows:
Overall Height: Approx 90cm
Widest Point: Approx 53cm (shoulder to shoulder)
Internal width at rear of base: Approx 33cm (actual seating area)
Internal width at front of base: Approx 36cm
Note: We now have 5 sets of black with grey centre, 4 sets of black with red centre and 4 sets of black with blue centre remaining so get in quick to avoid missing out.
The black/red version is winder type, and the black/grey and black/blue versions are lever type
Cheers,
Steve
Cheers,
Steve
Also interested in a all-black set of seats for my R33.
Out of curiosity, do you have any seats currently in stock that are the same style as the black ones? I only ask as I wouldn't mind coming down to have a look first before going ahead with the purchase.
Thanks
Hi mate, we sure do. Feel free to drop by anytime and have a look
Regards,
Steve
The modifications to the universal rails to get them to fit your car, it's a simple welding job right? My mate is a welder who could do it for me for nothing if this is the case (he's a professional). Or is the mod something you need to get done by an approved workshop for safety reasons?
Hi mate, thanks for your enquiry. The modifications required are generally minor depending on the car the seats are being installed in.
We recommend having them fitted by a knowledgable workshop or competant welder.
Cheers,
Steve
if they do bolt straight up to brise rails, how much can we purchase bride rails for?
We found that the genuine Bride rail needed a few minor changes before the seat could be bolted up as 1 or 2 of the holes didnt quite lineup and had to be redrilled on the rail itself to suit
Cheers,
Steve
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
