  • Replies 175
Posted Images
What size are they? I am typical small japanese style person size and i dont have larger friends to be passengers.
Do you have a picture with someone sitting in them?
Hi Alex, we dont have any images showing people sitting in them, but the approximate dimensions are as follows:
Overall Height: Approx 90cm
Widest Point: Approx 53cm (shoulder to shoulder)
Internal width at rear of base: Approx 33cm (actual seating area)
Internal width at front of base: Approx 36cm
Regards,
Steve
  • 4 weeks later...
  • 5 months later...
im itnersted however wandering if you can get rails for a 33gtst or apprently bride rails ? i got told to get a aftermarket seat fitted ur lookingat around 400 bux
Kennedy: The forum special is still available, though we are waiting on more stock of the red Bride style seats, we only have all black in stock currently.
Sammie: The cost of installation tends to vary depending on who does it. We recommend using a reliable and competant workshop or fabricator so you dont pay through the nose. We have supplied genuine Bride rails for some customers however they are quite expensive and comparable in cost to having the universal rails customized.
Hope this helps, if you have any further questions please dont hesitate to ask.
Cheers,
Steve
PM Sent.
Are you getting in the black seats with the grey inserts too?
Hi Sam, we have no plans to get more stock of the black with grey inserts at this stage im afraid.
We will arrange to have a set of the black Bride style seats put aside for you, please pm me your full name so we can get this finalised.
Cheers,
Steve
  • 1 month later...
bueller?
I really want to see one of these fitted on the drivers side.
I've done it but I havent got photo's. Gimme a couple of days.
The fit was a nightmare. I just ended up modifying some second hand genuine recaro rails to make it fit and so I could have the option of bolting the seat belt buckly to the car rather than the seat. Everything you see in the photo's is what you get. You dont get an sandwich plate to go between the seat and chassis
Hi Steve,
I am interested in 2 sets as I want to customise the car and run a set of these seats also in the back instead of the current rear seat. The kind I am after is as per your picture with the black and blue seats ? Do they come in Vinyl or Leather ?
Can you provide me with a price and delivery to Melbourne please ?
Cheers,
Sam
Hi Steve,
Cheers,
Sam
Hi Sam, unfortuantely we only have the Bride style seats available in black or red at this stage.
They come in mesh type fabric only.
I will pm you a total price including delivery shortly.
Cheers,
Steve
Using genuine Recaro or Bride rails makes the job a lot easier. We found that only minor changes are needed if you use off the shelf rail kits, ie on the seat we tested with genuine Bride rails we only needed to elongate a few holes and that was it.
Steve
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
