Hi guys. Hope you can help.
The power steering on my R33 GTST started to make whining noises when turning the steering wheel. I've checked for leaks and the power steering fluid is at the right level.
I took it to my mechanic and he has tightened the belt on the tensioner. He said the belt was still in good condition and not due for replacement. It was actually better for a day or so but now has gotten worse. The whining noise has gotten louder and now there is a sort of metallic scraping noise at very low or stand still speeds. All these noises are when the steering wheel is being turned and not when driving is a straight line.
But when the car warms up the noises is more sub-dued only really loud when cold.
What am I missing?? Pump on it's way out?? I hope not!
https://www.sau.com.au/forums/topic/86665-power-steering-noises-when-turning/
Just had the powersteering fixed on my R33. Sounds like the same symptoms. My mechanic flushed the fluid out (reckoned it was contaminated) and replaced the spring in the relief valve. Quiet as a church mouse now. Was thinking new a new pump was on the horizon but as usual turned out to be the little things...
Damian
Iusedto have that problem as well on my old skyline, the power steering fluid was leaking until it was empty. I filled it back up and it was fine again............until it leaked out again.
Took mine to the mechanic and just by hearing it..he knows exactly what's wrong -- he showed me an Additives and told me to get them from Aussie Auto Warehouse -- cost $17 i think -- poured them into my power steering reservoir and WALA-- noise is gone.
its called LUCAS stop leak for power steering.
no more squeeking noise.
Nismo can you please change your avatar before you get ppl who access these forums from work in the shit.
  • 3 weeks later...
Finally got my my car fixed over the weekend.
Yup, as what Dman said... the power steering fluid was contiminated and heaps of air bubbles in the system. The fluid actually looked healthy in the resovior (green in colour) but when it was drained out, it was near black.
Flushed and filled with new fluid and noise gone...!
  • 2 years later...
Hm, my daughters R33 has the same problem, any quick tips which fluid to buy?
(like need special sort maybe?)
I guess I could ask my mechanic to do it but he'll charge like he always does..
i have the same problem
im gonna try this one if it doesnt work im takin it to a mechanic
Awesome revival.
Just like most additives, IMO, they are a temp fix for ppl wanting to SELL the car...(coolant stop leaks, tappet quietener etc) - not for enthusiasts.
My car made some awful noises as well, though it was loosing fluid.
Degrease pump, reservoir and lines, and look for leaks. If found, fix, flush and refill.
Awesome revival.
+1 with GeeTR
ok i bought the lucas stop leak thing i put in and it did NOT work! best bet is to take it to mechanic.
Edited by 5hu7o
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
