Climate Control Problem
Rusty gold sadly only two Gtr’s and two rwd boats (lower middle class bogan)
Also possible you have a fuel pump or regulator issue, it runs OK when it is trying to be rich when cold, but runs badly/lean once it is trying to run normal. Put a fuel pressure gauge into the feed line and check that too.
2 spots that my exhaust guy joined the 2 pipes together Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
