i used serenity and i can't recommend sound deadening enough.
for $100-200 spend you get an absolute audible difference.
if you spend an extra $100-200 on HU, sub, amp & splits you won't be able to pick any difference.
i sound deadened both doors and under the rear seats. the doors are the very least you should do.
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-1572417
I used about 8kg of SD.
I won't install another system without sound deadening atleast in the front doors - I didn't want to weigh my car down too much I just wanted to get the most from my drivers - which it did.
Wolverine is right, it's the most noticable difference, I'll just add it's probably more useful when you're using quality equipment in the first place, so if you're using sony explod gear I wouldn't bother. I have focal kvp2 splits in the front doors and wanted to get the most out of them.
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-1573558
I'm not sure if you have it over there, but Bostik Automotive Sound Deadening panels are a very good bang for buck alternative.
Iver here it is about $100nz for 10 x 500mmx500mm sheets. I'm pretty sure that the fusion stuff is this just rebranded.
I'd rate it as good as brown bread.Dynamat is better, but maybe 15-30% better for about 400% price increase.
As has been said, sound deadening your vehicle will make a VERY noticable difference in road noise and getting rid of rattles/resonance from your speakers.
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-1574958
  • 6 months later...
Please excuse my thread grave-digging operation,
But does anyone have more info on where you put it? I was thinking of is sticking to the inside of the outer door skin, naturally, but how much you need to cover?
What about the inner chassis of the door, (the bit that you screw the door trim to) did you put anything behind or infront of it as well?
Thanks for any input...
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-2030471
wow, you did everything then.
What diod you use to do the access holes?
Did you just cut out some MDF and silicone in?
Is that in an R32?
Looks different to mine - r33.
I take it you've used dynamat on the metal parts, or is it..
What's the TAC stuff? is that like brown bread?
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-2030669
Dynamat extream on the metal bits. Holes are filled in with aluminium. Stereo shop doesnt want any come back calls from wood rotting and rust problems. Also less and thiner. So then thats silconed in.
Its also got some foam behind the speakers themselfs, just makes that area more dead. Plain chant or something, from fusion.
The tac-mat is a closed cell foam to stop any rattles from the door cards.
It all works very well.
But inregards to the comment $200 anywhere else wont make the same difference... Im not so sure about that. Get an eclipse head deck, then tell me you dont notice the difference. Really for a good system you need everything.
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-2031179
Im gonna get mine done as well in april sometime hopefully.. so will keep you posted.. for hertz 165s..
Is it worth gettin the full door deadend or half the door?? coz theres a huge difference in price!!!
Do it once and do it properly. I seriously noticed a fairly big difference with getting the acess holes filled. You probably dont need to go to the extent of foam on the door cards, but Im (trying) to win or place in some SQ comps. So every little bit counts.
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-2031522
  • 1 month later...
im looking at sound deading my boot lid rear quarter panels, doors etc etc and wahnt to know how to go about it as is very pricy to get someone to do it for you
pull all the panels off. clean with prepsol - apply dynamat. if youget stuck or want a box of it fire me a pm.
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-2145673
I've been looking into sound deadening and looking at getting some dynamat xtreme.
Was thinking about putting an amp and sub in but thought I would try sound deadening first and see how it goes.
Found this tutorial on the CAA website..
http://www.caraudioaustralia.com/content.php?contentID=19
There's also these ones on the Dynamat website..
http://www.dynamat.com/technical_installat...ation_menu.html
If anyone knows of where to get some sound deadening stuff cheaply then please share the wealth :worship:
What are some of the options for deadening the area directly behind the speaker?
https://www.sau.com.au/forums/topic/86699-dynamat/#findComment-2146886
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 馃槀馃槀 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 馃槃
    • They sure do, great for when you need to chuck a sickie 馃槄   You should definitely give the beast a squirt on the track, great to enjoy the car
