Splitfire Coils Suit R34 GTR and R33 GTSt Series 2.
I have them in the original box, used for only a few days,
Increases Spark and maximum power your engine can produce.
Worth $750.
Sell for $500.
Edited by quicknissan
https://www.sau.com.au/forums/topic/86713-rb-splitfire-coilpacks-in-the-box/
Splitfire Coils Suit R34 GTR.  Got them from Japan for my R34 GTT, but they are for a R34 GTR so did not suit my application.
Worth $750.
Sell for $500.
anyone know if these can be fitted to an R32 GTR (remove the ignitor ?)
if so I'll take em
  • 3 weeks later...
So what happened to the guy who sent you money?  Don't the coils belong to him?
lol, if someone sent me money, why would i be trying to sell them ? Dont you think that he would be on here complaining that he hadnt got them ? I'm not a freaking theif. No one gave me money, I still have coils, so they are still for sale !!!
if u really do have them still and you really are trying to sell them why dont u reply to the people that have genuine interest who u just ignored??? I agreed to your price that you offered them at and then never heard from you again
Ok, I realised it was because my PM inbox got deleted that I didnt know what was going on. I lost addresses and phone numbers of people i had to contact. Looks like it is sorted out now, sorry for the hassle, next time I'll write things down lol.
quicknissan
maybe doesnt like COD, cant get away with it? lol.  Something definetly looks suss mate.
whats with all these people thinking there is something fishy or suss ? There are alot of synical people out there. I suppose people have to be carefull though, i mean i dont like buying stuff off the internet, so i sort of know what you must be thinking. Looks like it is all sorted now though, sorry for the extra hassle :-)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
