My hicas light has started to come on after a bit of driving too. I've just put on an aftermarket steering wheel, but the bloke said that it should be ok.
I've checked the fluid level and it is all good, so i would have to guess that it is the steering wheel.
Anyone know a good place to go to get a boss kit for a momo steering wheel that doesn't screw around with hicas?
https://www.sau.com.au/forums/topic/8673-hicas-light/#findComment-138880
I am having problems with my hicas... After about 15 - 20 minutes of driving, the light comes on. There's no noticable changes to the way the car drives, and I can see the rear wheels move ever so slightly while steering to full lock. The first thing I did was to top up the power steering.
I have been trying to get the diagnostics to appear, with no luck. Either I'm doing it wrong, or there's something wrong with a sensor like brakes or speed, etc... So just to verify my procedure:
1) Turn off car, leave in neutral
2) Turn it on
3) 20o left and right 5 times.
4) Pump brake 5 times
5) Press brake again
6) Drive (or roll, really) 5 metres ahead really slow.
1) From the time I turn on the car, to the time I start the 5m drive, how many seconds do I have?
2) In step 5, do I hold the brake in slightly and heel-toe it foward, or tap it in and out?
My car is a stock R33 '95 model. The 4WS appears to be fully electric.
https://www.sau.com.au/forums/topic/8673-hicas-light/#findComment-172695
i used to have this prob - just went away about a yr ago by itself.
whenever it came on, i just pulled over and restarted car... gone for another couple of weeks.
the only time it would come on for me was when doing long straight stretches of road that required next to no steering.
i used to drive a same long stretch of road frequently - 7 out of 10 times the hicas light would come on... ALWAYS at the same spot give or take 100m
https://www.sau.com.au/forums/topic/8673-hicas-light/#findComment-172727
im dont understand what you mean here? if you are saying your rear wheels move when you are not in diagnostic mode just sitting on the spot and you turn your wheel you are wrong!
Skyline 4ws only opreates when you are travelling and not stationary unless you are in diagnostic mode!
https://www.sau.com.au/forums/topic/8673-hicas-light/#findComment-178026
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
