1) From the time I turn on the car, to the time I start the 5m drive, how many seconds do I have?
do it as fast as you can but make sure you are turning the wheel enough....if it doesnt work try turning the wheel a little more....
2) In step 5, do I hold the brake in slightly and heel-toe it foward, or tap it in and out?
tap it in and out
I've put my car into diagnostic mode many times however last week when i tried to put a friends car into it i couldnt so just keep trying!
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-178035
i got aftermarket wheels, hicas light comes on after 10-15 mins of driving over 80km/h, on freeway etc. If i turn the car off, and then on again it goes away. I tried getting it into diagnostic mode a few times, but with no luck.
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-178518
Originally posted by akeenan
im dont understand what you mean here? if you are saying your rear wheels move when you are not in diagnostic mode just sitting on the spot and you turn your wheel you are wrong!
Skyline 4ws only opreates when you are travelling and not stationary unless you are in diagnostic mode!
And yet it does. Perhaps the light is coming on because of it being unable to determine the speed of the car, and for that reason the wheels move... Who knows until I can get this diagnostics mode working.
Anyway, I'm going on the dawn cruise to the gong tomorrow, so I might be able to get some info on it there...
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-178536
Originally posted by GTR King
I wonder if it has anything to do with Engine speed vs Tyre diameter. Maybe it affects the ECU if the inputs r incorrect. Im no electrician but after what b003t said it maybe be worth asking.
Go on laugh at me but im only trying to help :]
Well I'm even less of an electrician. But they're stock wheels and I don't think there's anything special about the tyres - they're still the ones the compliancer dude put on. Aside from an after-market stereo, I believe the speed alert chime has been disabled (unless I go deaf past 110kph :D) but that seems all... Who knows. :D
I think I'll try and get a knowledgable guy / girl to try and get the diagnostics mode working... :
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-178547
  • 3 weeks later...
My Hicas light comes on every time after about 10km, turn car off and go again for 10 and on it comes. Rang the guy who sold it to me who checked with a mechanic mate etc etc. Turns out I have an aftermarket diff - locker apparently, and this is what happens when you mess with the original diff.
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-210682
Hicas on the R33 is fully electric. Topping up the power steer fluid won't do anything for you.
I never had a problem with my hicas and I had aftermarket 17" wheels on. I can't see how that could possible make a difference anyway, but it certainly didn't in my case.
My car was a R33 GTST
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-254933
  • 3 weeks later...
Originally posted by Hicks
Mine comes on sometimes when i've been driving for a while, but if I turn the car off and start it again it goes off. I don't worry about it. Get it checked out if your a bit worried.
I have this problem too..
My problem is that the contact in the steering wheel isn't making contact so the car cant sense that the hicas is there.. or something.
It only happens when I go on the freeway and drive for extended periods of time without turning the wheel too much.
It just resets the computer when you turn it off so the sensors are working again. It was going to cost me $300 to get the part and more for the install. But I'm not too worried. It's not harming the car in anyway.
https://www.sau.com.au/forums/topic/8673-hicas-light/page/2/#findComment-293270
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
