Hi peoples,
I have just signed up to the site and it is very cool. I have recently purchaced a mildly worked R32 GTS-T which I am very happy with. It is still running the standared intercooler and I want to upgrade to a new/bigger front mount intercooler. Where sould I get this done, (I live in Melb), and should I spend the doe on a custom job or not.
Cheers
JL :P
https://www.sau.com.au/forums/topic/8686-intercoolers/
ARE do a full kit for the R32 GTSt and from all accounts their coolers are very good. The guy has done many hours R&D getting them right. Its $1178 for the cooler, or about $2100 for the whole kit. Im considering one of these myself at the moment, as is my brother.
check out: www.are.com.au
And i sincerely hope thats not a stock turbo you plan on running 20psi through..... can you say BANG?
Red17
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-127820
Red17
for $1200 u can get a cooler the size of 900 x 450 x 96 which is a monster and wont fit a r32!
My new cooler is 600 x 300 x 76 and fit real nice in the front of my car!!
AVO are a bit dodgy these days and u will be paying for their name not for the quality of their work.
Use ice they did the fitting of my new cooler and do a great job.
And i hope u aint planning on running the stock turbo at 20psi either!
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-129942
Depends on your goals.
Stock turbo? If so just remove the panel under the front guard behind the stock cooler.
After extra acceleration? Unless you want to track race on a regular basis save your money and don't buy a front mount till you do something with your stock turbo , like high flow it.
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-130486
after putting my new fmic on, and seeing how crap the stock cooler is i dont know y u keep saying not to put a fmic on. The stock cooler is a piece of crap, the air tubes on it are miniature at best and the design of the end tanks is useless. Its so small that at the speed the air goes through it, there is not enough surface area for any cooling to occur, and it was full of oil resisdue. I got a gain on 25rwkw at same boost just by putting a fmic on!
With the stock cooler and 0.8 bar i got 155rwkw and now if u see the red graph i got 165rwkw at on 0.5 bar and the green bar is 183rwkw at 0.9 bar!
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-130535
Mate as far as I know the stock turbo's are ceramic based and if running 13psi (recomended MAX!!) you still have a chance of blowing your turbo!! I would say buy another turbo and FMIC together so save up a bit more and get it all put in at once....
Someone please correct me if im wrong.....
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-131288
    • Ah yeah I forget we aren't talking about an RB.
    • Fellow ADHDer to fellow ADHDer; Don't chase that paint perfection. Paint the bumpers, and put them on.  Leave the respray for another day. Plus, no one is going to see those old areas above. Any spots of surface rust, give them a clean up, prime, then hit with a white paint just to protect them from rusting. Again, no one can see it.   #Mine hasn't been on the road since 2011 cause ADHD... I've slowly learned not to keep f**king with shit if I don't need to...
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
