Hi peoples,
I have just signed up to the site and it is very cool. I have recently purchaced a mildly worked R32 GTS-T which I am very happy with. It is still running the standared intercooler and I want to upgrade to a new/bigger front mount intercooler. Where sould I get this done, (I live in Melb), and should I spend the doe on a custom job or not.
Cheers
JL :P
https://www.sau.com.au/forums/topic/8686-intercoolers/
ARE do a full kit for the R32 GTSt and from all accounts their coolers are very good. The guy has done many hours R&D getting them right. Its $1178 for the cooler, or about $2100 for the whole kit. Im considering one of these myself at the moment, as is my brother.
check out: www.are.com.au
And i sincerely hope thats not a stock turbo you plan on running 20psi through..... can you say BANG?
Red17
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-127820
Red17
for $1200 u can get a cooler the size of 900 x 450 x 96 which is a monster and wont fit a r32!
My new cooler is 600 x 300 x 76 and fit real nice in the front of my car!!
AVO are a bit dodgy these days and u will be paying for their name not for the quality of their work.
Use ice they did the fitting of my new cooler and do a great job.
And i hope u aint planning on running the stock turbo at 20psi either!
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-129942
Depends on your goals.
Stock turbo? If so just remove the panel under the front guard behind the stock cooler.
After extra acceleration? Unless you want to track race on a regular basis save your money and don't buy a front mount till you do something with your stock turbo , like high flow it.
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-130486
after putting my new fmic on, and seeing how crap the stock cooler is i dont know y u keep saying not to put a fmic on. The stock cooler is a piece of crap, the air tubes on it are miniature at best and the design of the end tanks is useless. Its so small that at the speed the air goes through it, there is not enough surface area for any cooling to occur, and it was full of oil resisdue. I got a gain on 25rwkw at same boost just by putting a fmic on!
With the stock cooler and 0.8 bar i got 155rwkw and now if u see the red graph i got 165rwkw at on 0.5 bar and the green bar is 183rwkw at 0.9 bar!
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-130535
Mate as far as I know the stock turbo's are ceramic based and if running 13psi (recomended MAX!!) you still have a chance of blowing your turbo!! I would say buy another turbo and FMIC together so save up a bit more and get it all put in at once....
Someone please correct me if im wrong.....
https://www.sau.com.au/forums/topic/8686-intercoolers/#findComment-131288
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
